Question about Mitsubishi WS-55411 55" Rear Projection Television
PICTURE COLOR GOES TO BLACK & WHITE SOMETIMES FOR ABOUT 5 SECONDS EVERY NOW AND THEN IT'S HAPPENING MORE OFTEN
  • 1,476 Answers
Emans626,
You have some bad solder joints in the set. Located in the area of the video IC. I would resolder all the connections on the board. You can locate the board by taking the back off with the power disconnected of course. The board on the left should be the small signal board. Using caution remove the board and resolder all the connections on the board, or you could order a new board from http://www.encompass.com and just replace it. Either way it should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Sep 27, 2010
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
Black and white picture and white spots
if it is the color wheel issue, you can replace it, i have this acer X1160 color wheel, if you need please contact me
Jul 11, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
The tv on;y shows a small pip window in color if it is a large picture the picture is in black and white how to fix?
Whatever input video signal you're using, PIP should be in color. What are you using out of your dvd for the second video input source, composite or component? Composite you should always have color, Component, if you have a bad red or blue, and just the green is working, you will get black and white. The green is the luminence signal.
Nov 23, 2011 | Televison & Video
Color image is coming out black and white
does it happen on the any input or just on tv setting?
if it's judt tv then sounds like the tuner, if it's on any input, then the video chip or a decoder on that board.
Apr 08, 2010 | Philips 26PFL5322 26 in. LCD TV/HD Combo
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Kodak ESP 5 runs out of ink after about 40 pages of standard text black & white documents. Also the color ink level is dropping, but no color is being used (the printer is set for black & white...
As far as the quantity of black & white - to get more out of it - go to start menu.. Click on on settings,, then printers,, Right click on the ESP 5,, click on printing preferences,, then clcik on draft,, then click on (at the top) advanced,, click on black & white.. Then click on apply then ok..
Now - every time you print it will be in this mode.. If you want to print in color - you will have to choose that each time..
For you black & white docs - this will print faster & use allot less ink..
As far as your color issue & puddling - It could be the printer head.. If it is new enough - call Kodak & maybe get a replacement.. If to old - maybe keep the color cartrige out and caped with the plastic caps until you need to print color.. Snap it in & out as needed..
I hope this helped..
Jun 11, 2009 | Kodak ESP 5 Printer
COLOR GOING OFF AN ON (COLOR TO BLACK AND WHITE)
see the back side of the cabinet for main screws, open them to get inside the cabinet
there you can find the main curcit board.. there look for bad solder joints
good luck
cheers!!
Feb 08, 2008 | Toshiba 55H70 55" Rear Projection...
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Mitsubishi WS-55411 55" Rear Projection Television Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
