Question about KitchenAid KEMC308 Electric Double Oven
KEMC308 Microwave oven door
Microwave door use to come down softly now it slams all the way down. What could be the cause?
  • 2 more comments
  • Anonymous Jun 16, 2008
    Where can I buy the spring??
    Thanks
  • thefixitguy Jul 30, 2008
    I think this is my issues as well, I thought the spring piece was small but looking online for parts it looks like this spring/bar part goes the entire distanc between the hinges, maybe 14-16 inches or so? Hope I'm in the right ball park on this.
  • Marc211 Nov 12, 2008
    I guess that I have the same problem ... The last thing I want is to open the door and find out that I can put it back together. So, when Reg501 writes that changing the part is somehow difficult, would anyone have any recommendation before I open the microwave door ?
  • Greenius May 11, 2010
    reg501, this is exactly the 2 steel rods that the tech guy replaced, but there still isn't any tension or spring in the door so it falls with all its weight if you open it... what did my tech guy do wrong? he says its fixed but its not right if the door slams down if you open it...
Had the same problem and bought the part online. It's not difficult to replace, simply hold the door by the handle as you loosen the 2 screws. Put the face of the door on the floor and remove 2 screws holding the plastic insert. You will have to remove the front vent panel (2 Screws) just below the microwave door.Then you might have to move the oven vent over to get to the final 2 screws on the bottom of the plastic panel. Once you have the palstic panel off the springs are exposed, simply look at how it is placed in the holder before you remove the damaged one. Replace and then re-assemle the door.
Posted on Jan 30, 2009
  • Pete Rigazio Oct 14, 2011
    Just changed one of my springs, ordered two just in case the other one snaps. I lucked out in that I didn't have to move my microwave from its mounts. I have the built in oven, convection oven microwave unit. The vent for the oven that has to be moved to the right to remove the last screw in the plastic panel had a short fat phillips screw holding it in, I was able to use a pair of needle nose vice grips to grab the head and turn the screw out. Replacing the spring was a snap after that. Thanks for the instructions.
    Pete
I just order the left side spring online and hope the replacement is as easy as described
Posted on Jan 16, 2010
No problem, internet page: repairclinic.com is my solution,
Posted on Jun 30, 2009
  • 413 Answers
This microwave door uses two steel rods that cross one another inside the door that twist as the door opens. These rod are prone to breakage. A little difficult to replace. Use caution when removing the two screws in the door. The entire door will come apart and want to fall to the floor.
Posted on May 31, 2008
The microvave oven has "door" in the display and the microwave doesn't work
Then one of the micro switches either has failed or has slid out of position
Nov 29, 2013 | KitchenAid KEMC308 Electric Double Oven
My KEMC308KWH01 Microwave got "DOOR" Error
Almost certainly the limit switch is open circuit. Need to pull out plug, remove cover :then using a meter check the normally open and closing of the various limit switches.Carefull with those limits ok, all have very exact functions.
Jun 06, 2010 | KitchenAid Architect Series KEMC308KSS...
Problems with KitchenAid KEMC308 Electric Double Oven DISPLAY
either the touchpad ur pushin or the control board behind is has a bad connection or one of them is defective......u will prob need service some of those u must pull out to acess the componets, not a cheap repair if one of those, usaually at least a couple hundred dollars per part
Feb 05, 2010 | KitchenAid KEMC308 Electric Double Oven
Light is out in Microwave Oven
You have to pull the complete unit from wall, take top setion apart to get to lamp, do not attempt to change this lamp unless you have knowledge of electricity and what it can do to you if you FAIL TO TURN IT OFF FIRST.
Oct 01, 2009 | KitchenAid KEMC308 Electric Double Oven
KEMC308 has frozen, unusual looking display info. Nothing works.
Try unplugging it or flipping the breaker to the oven. Leave the power off to it for a minute, then turn it back on.
Mar 27, 2009 | KitchenAid KEMC308 Electric Double Oven
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Jun 14, 2008 | KitchenAid KEMC308 Electric Double Oven
KitchenAid KEMC308 Electric Double Oven Logo
994 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
