Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Blinks? How many blinks of standby LED is failure code. MAy have to unplug TV for a while to get the real first code that started the whole mess. 6-7 blinks usually mean voltage issues on D-board.
  • BP2008 May 27, 2008
    Sony direct parts: 1-800-488-SONY (7669). If you can turn a screwdriver and identify the failing board it may be fixable. The D-Board is typically the culprit in most cases but you have to count the number of Flashes on the LED to narrow down which board is failing.
  • kathyg72 May 28, 2008
    TV blinks when it turns on (about 20 times) then stops blinking and the red "lamp" light goes on. TV never really turns on. Should I do more than just unplugg for a while?
Help, dennistredden@comcast.net
sony 32 trinitron tv
takes awhile to come on then when it does it blinks all the time..
sometimes it stays on for a few minutes but then goes back into a blink mode..
can you tell me what is wrong and where, online can i order the parts. I've never worked on tv's but i don't have the money to call some one.
thanks in advance
mr. redden of highland, mi.
Posted on May 26, 2008
Has audio, but why no video?
Please describe how you TV is setup and connected to devices.
Check to make sure you have the correct input selected.
Also, check to make sure you have correctly connected the video cables and that you don't have bad video cables.
Another thing to try is unplug the TV for 30 seconds.
Prepare to observe the Standby LED on the lower front of the TV.
Plug the TV back in and see if the Standby LED blinks, counting the number of blinks. These blinks are the self-diagnostic codes.
Post your findings here.
Mar 31, 2016 | Sony FD Trinitron WEGA KD-27FS170 TV
Tv Won't come on
I suspect a power board failure but to be sure i would have to know how many times your light is blinking as there is a code to it. please repost with number of blinks. This is a common problem with this brand of sony televisions as far as I can tell from what i have been reading online. If you are still under warranty you should contact Sony. If you need further help from an expert please let us know the number of blinks.
Aug 03, 2007 | Sony KV-35S42 35" TV
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 19, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
How to fix my Sony bravia KDL-40S2000 turns on then goes on standby blinks 4 times an want go off until you unplug it plz some one help
Jan 08, 2015 | Sony Televison & Video
Sony bravia flashing light fix
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 01, 2014 | Sony Televison & Video
My sony bravia LED flat tv goes on and standby then on and then stanby again..and afterwards stucks on standby at all.Is the system controller has failure or its power supply?
Before go, the standby/power LED will blink to a certain times, and these blinks are called blinking codes, and are fault indications. From the number of these blinks occur at one time switch ON, you can get an idea about the fault circuit stage inside the TV. If you wish to get more details about these blinking codes, check this link. if you're sound in electronics, you may get it repaired by yourself.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | RCA Televison & Video
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No power black screen standby light flashes
Hi, Most new Sony TVs have a built in self-diagnostic feature. One of the led lights would be blinking. The number of blinks (on/off) is indicative of a code. The code represents a system fault. For example on some versions, 3 blinks indicate diagnostic mode where the builtin protection has kicked in (very likely a powersupply problem). How many blinks is the standby light doing? Due to the technical requirements to repair this TV, you would probably require the services of a qualified TV professional very familiar with Sony models. You can try a hard reset by unplugging the unit off from the mains for a couple of hours. If a no by then, we're back to the tech. Good luck and kind regards.
Aug 26, 2007 | Sony KV-27S42 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
