Question about Vacuums
How do i get it appart???? i can't get to the front screw.
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 27, 2010
Why did the cord jam when rewinding
Take it back to retailer as if you take it appart to fix your self and it throws a major fault before the first year is up the warranty may be voided
Nov 25, 2015 | Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
A sock is stuck in the nozzle. won't come out . how do you take it appart?
Remove the power head from the wand. Turn it upside down on a table or counter. There are 5 screws to remove to take the head off. There are
3 on the long part just in front of the brush roller and 2 more on each corner of the short part. Once you have the hood off you will be able to remore your sock, then put back on the hood.
May 13, 2010 | Electrolux Guardian Bagged Canister Vacuum
THE BRUSHES DO NOT TURN ANYMORE IS THERE A BAND THAT ASSISTS IN TURNING THE CLEANING BRUSHES? WHERE IS IT LOCATED? HOW DO i REPAIR IT?
There is no belt on this machine. The part that makes the brushes turn is called the Turbine. Here is the part you need
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001019, 43191006, 91001097 - Free Shipping cost of this item is $ 37.99. This a difficult repair, in that you have to the entire front head appart in order to access the part. If you would like a schematic, please send an email to
bschwartz@govacuum.com
Apr 27, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Apr 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Lost screw to front floor nozzle.
Go to http://www.bissell.com/Product_Search.aspx?Criteria=9500+pro-heat
and click on parts & accessories.
Aug 17, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cleaning under floor nozzle window
make sure you removed the 2 screws closest to the front then lift up on the front end of the window sometimes its sticky but it will lift up. when putting it back on put the tabs on the back end in first then slip it down in the front , replace 2 screws
Jul 29, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell pro heat 7901w
You need to order a hood assemble. it comes with the switch. make sure you are careful putting the hood back on. in some cases you may need to get the whole housing. there are 6 screws holding it together. before putting the housing back make sure to put a small block of wood under the bottom between the wheel not on the wheels. this will help to lift the bottom so you can screw back the housing.
Feb 09, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Jan 08, 2008 | Hoover S1361 Bagged Canister Vacuum
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
