Lh earphone of my Shure se210 volume is very low. Have cleaned the earpiece multiple time using the supplied tool. It sounds louder in the rear of the earpiece than inside of the ear. Any suggestions?
  • 17,130 Answers
The dirt is clogged in the front end if the sound is clear at the rear. So it will be needed to clean the earpiece once again taking care to see that there is no dirt/ear wax clogging the sound vent.
If possible use fine bristles to brush out or clear the openings till the clarity improves since you mentioned the earpiece is working well when heard at the rear, if not the LH can be weak.
Posted on Sep 27, 2010
Testimonial: "Thanks ! I will try your helpfull response!"
Karbonn k770iheadphone simbal
Posted on May 18, 2011
Why have I lost volume in one ear
there will be some loose connection in wire...or else u may have dropped down the earphone....maximum it will be wiring problem....
Aug 20, 2014 | Sennheiser Genuine Cx270 Cx 270 In Ear...
Louder in one ear than the other
There is a possibility that your earphones need cleaning. Take off the tips and gently brush the metallic mesh with some cloth. Then dip each earpiece into drop of alcohol (you need to dip mesh only, not the whole earpiece). Then wipe it clean with cotton bud or something similar. Next, dip your earpieces the same way into drop of hydrogen peroxide and leave them there for few minutes. After that, wipe them again.
I used this method on my ie8 and it really helped.
Feb 21, 2012 | Sennheiser IE8 Headphones
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have bought a pair of Shure SE210 headphones for my iphone but the sound is lacking all the low frequencies for most of the music or videos i try to play. The headphones work perfectly on any other...
No, there are no known issues. Typically a lack of bass response is due to a poor seal with the ear canal. The headphones use sealed ear canal is a resonant bass chamber. Thus, if there is not a good seal, the bass will be significantly lower.
Jul 07, 2010 | Shure SE210 Consumer Headphones
Shure earphone problem
There is no fix for that. They will need to be sent to Shure for repairs. Contact Shure Service.
May 01, 2010 | Shure E3C Consumer Headphones
Low volume on calls. cannot hear caller unless i'm in an absolutely quiet room. I have the master volume at max. also, the flash is so bright that the pics i take are overexposed. Can i shut the flash off...
for the low volume, the fault is from the earpiece. Trust me, I faced this same problem and when I changed the ear piece, I began to hear calls clearly.
You could also get a earphone and use it to receive and make call pending the time you get the earpiece fixed. Earphone will even be much louder.
Concerning the flash, do some adjustment settings as you rightly suggested.
I wish you the best.
Dec 31, 2009 | Cell Phones
I can`t listen the radio station
Hi,could be low volume level.You can increase it with the button on the side.If no joy try use other earpiece,if nothing again then there's a device fault. You can try reflash firmware using Nokia PC Suite-Firmware updater.If after that not working then go to Nokia centre,if under warranty repair is free of charge.
Rate me if helped.Thanks.
Apr 25, 2009 | Nokia 6120
Shure E3C
This isn't really a solution, but should be relevant.  If you think that cleaning might be the issue, don't be too afraid to really dig in there.  The part you see is just a cover, not the speaker diaphragm itself.  I've had the tip part fall off (well, sort of break off) and that whole assembly doesn't do anything but cover the speaker.  The real deal is pretty deep in.
Jul 02, 2008 | Shure E3C Consumer Headphones
Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Mar 13, 2008 | Nokia 7370 Cellular Phone
K750i low volume in the playback ,please give me a solution
Well... The speaker is ok and if you're using the headset it should be loud enough for you. If you want it to be louder just use earphones/headphones that are sound isolating to block out ambiant noise. The hpm-70 can kinda do that because they go in in your as opposed to sitting on the outside of your ear. The earpiece volume is really loud. I found it hard to hear to people in some places.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 15, 2008 | Sony Ericsson K750i Cellular Phone
836 people viewed this question
 Grubhead
Grubhead
