Question about Mustek Scan Express 1248UB Flatbed Scanner
When I try to access my Mustek 1284UB scanner, using Microsoft Picture Publisher, I get the message "The scanner is not connected please check the cable"
  • 1 more comment
  • antonysobey Sep 27, 2010
    Dear Taran, thank you for your solution, I followed your easy to follow instructions and the scanner is now working perfectly. Many many thanks for your expertise.
    Best regards,
    Tony.
    Dear Taran,
    Best regards,
    Tony.
    A very helpful solution. Clear easy to follow instructions which completely fixed my scanner problem.
  • 10,515 Answers
If this is a PC running Windows Vista/XP/98, you must have the scanner USB cable disconnected and turned off while you do the CD install or windows may interfere with a generic driver.Then reboot and connect the USB cable.Then use File > Page Setup to configure the printer and scanner selections. It won't hurt to un-install with the CD, reboot and re-try the installation.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 27, 2010
Hello. Please help me. I have scanner A3 USB 1200 pro and Win7 pro 64bit. When I try install driver ScanExpress A3 USB 1200 WIN7 downloaded from Mustek site I get answer like "Can't get access to...
This might not be the best solution, but it won't take long and it's worth a shot. This is a known problem with some microsoft products. If you visit this microsoft site and click the Microsoft FixIt "Fix this problem" button, it may fix it on its own.
http://support.microsoft.com/kb/886549
You have to scroll down a little bit to find it. I'd be interested to see if it works, please comment and let me know. If it does not work, I apologize.
Mar 22, 2011 | Mustek ScanExpress A3 USB 1200 Pro Scanner
Need software to work
goto this web site:
http://www.mustek.com.tw/Download/driv_scanr/english/1200ub.html
this will give you the driver then just use it in microsoft publisher/word/page maker or adobey photoshop.
Nov 25, 2010 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Sterownik vista Mustek ScanExpress 1200 UB Plus
From reading around, there isnt one....But i found this post
I've just installed a Mustek 1200 CU scanner on Vista.
I used the XP driver from the Mustek website.
You have to temporarily edit the registry to make the installer think you have XP
In regedit, go to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\Cu rrent Version
Find the "product name" key. Carefully record what it says before you start. (eg paste it into a document somewhere).
Then change it to make it read: Microsoft Windows XP
Then run the Mustek XP installer, and change the registry key back to saying Vista.
The scanner works fine in Photoshop, for example, but the Vista scanning wizard doesn't detect the scanner. Don't think it uses TWAIN?
Aug 11, 2010 | Mustek ScanExpress 1200 Flatbed Scanner
I need scanexpress a3 usb windows 7 driver pls
I succeeded into installing and using the Mustek ScanExpress A3 USB!
I downloaded the driver for Windows Vista from the Mustek website, then did the following steps:
1. left mouse click on the web.exe downloaded file and choose Properties;
2. in Properties I checked "Execute this program always as Administrator" and "Execute in compatibility mode for Windows Vista";
3. without any scanner connected I executed web.exe, gave the authorization even if recognized certificate;
4. allowed the system to restart;
5. connected the scanner;
6. directly used it into any program.
Please let me know if these instructions was useful!
Regards and good luck.
Sandro from Italy!
Apr 13, 2010 | Mustek A3 USB Flatbed Scanner
Mustek Scanexpress A3 USB scanner stopped working
my scanmagic 1200ub is recognized by my pc but i keep getting a message saying"cannot locate component.could it be that particular port?
Mar 29, 2009 | Mustek A3 USB Flatbed Scanner
Mustek Scanner won't initialize
It could be something to do with the bundled software having a missing or corrupt TWAIN32 file.. But you can Scan using Windows XP itself.
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
Scroll down to the Scanning part, and see if that is of any use to you..
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Mustek Be@rPaw 1200 Flatbed Scanner
Mustek TwainScan 600 III EP Plus
Drivers are available from the mustek web site in US or Taiwan. See http://www.mustek.com.tw/Download/driv_scanr/english/600iiieplus.html.
You need an AC power adapter if you don't have one. The original was an YHI Power Adapter, model YC-1015-15, Input 100-120V, 60 Hz, 0.4A, Output +15VDC/1A. I know because I'm reading it off of mine (I am the original owner of one, this is about 10 years old). You can find new ones on eBay for $10 plus shipping.
Finally, you need a cable that connects the scanner to the PC using parallel port technology. Both ends are 25 pin Female, and the cable itself is marked as IEEE 1284 compliant. Cable is AWM E101344 Style 20276 30V VW-1 Space Shuttle. Must have 25 pin female connectors, check eBay or http://www.driverforum.com/controller5/10421.html.
Sep 10, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Packard bell branded Mustek Be@arpaw 1200CU+ scanner
FIRST and most important - uninstall any other attempts at scanner software using the control panel and add/remove software.
THen download and run this file: ftp://ftp.mustek.com.tw/pub/driver/BearPaw/1200CUPLUS/Windows/PS1G_WEB.exe
This works for my Packard Bell branded Mustek Bearpaw 1200CU+ scanner under XP Pro SP3.
On the same site Mustek also have Vista drivers available!!!!!
Sep 07, 2008 | Mustek Be@rPaw 1200CU+ Flatbed Scanner
Mustek 1200 UB Flat bed scanner
SELAM BENDE MUSTEK 1200 UB VAR XP NASIL çALIŞTIRA BİLİRİM XP DOSYAYI YüKLEDİM AMA çALIŞMIYOR 98 çALIŞIYOR YARDİMCI OLURSANIZ SEVİNİRİM TŞKLER danyal472004@hotmail.com teşekkürler
Feb 07, 2008 | Mustek A3 USB Flatbed Scanner
Mustek Scan Express 1248UB Flatbed Scanner Logo
366 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
