Question about Canon Cameras
My camera is constantly saying Err 99, how do I get it to stop doing that???
  • Canon Master
  • 17,129 Answers
This is an error in the control board and needs attention. From the outside you can remove battery for few hours and reset. If not I would advice you to contact canon as parts may be needed
Posted on Sep 27, 2010
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
Camera turns on and works but has constant error cf and when you try to format the card reads error 99
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Feb 13, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I receive Err 99, it says to re install battery or
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 14, 2010 | Canon EOS 40D Digital Camera
Err 99
If you're using a dslr type camera....with removable lenses.....try cleaning the electrical contacts, between the lens and the camera. remove the lens and use a pencil eraser...being careful not to get any debris in the camera or lens. dirty contacts cause a lot of problems. hope this helps.
Apr 06, 2009 | Canon Rebel XT Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My canon 20d stopped taking photos for no aparant reason. Kept getting error 99 and when I re insert the battery it starts clicking on it's own whether turned on or not. I sent it to Canon repair who...
If two cameras are doing it, I would suggest the contacts on your lens are dirty.
Try the following diagnosis steps for solving ERR 99 issues : -
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
