Question about Toshiba 56HMX195 52" HDTV DLP Projection TV
My tv screen will not come on, I hear the sound but the tv keeps turning on and off, plus it is making a buzzing sound, any ideas what it could be?
  • Toshiba Master
  • 5,138 Answers
Replace Lamp Mats has them for 99.00 1-800-628-1118
Posted on Sep 27, 2010
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming...
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming from the back of the unit.
Nov 15, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
LG LCD TV - Buzzing Sound and Faint Horizontal Lines
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module. They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV. They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
May 23, 2010 | LG 47LG70 42 in. LCD TV
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
LG `21` INCH TV
If it has been moved or bumped recently the sound you are hearing is the main HT lead that has been displaced. TGhis is a blasck lead with a rubber disk surround at its end that fits into the picture tube. Do not touch without turning TV Off and using rubber gloves to reinsert.
Please rate our help to keep us online
Aug 24, 2009 | JVC AV-48WP30 48" Rear Projection...
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Buzzing sound on Vizio Plasma TV
likely supply failure or shorted pannel driver. u should be able to unplug the pannel boards from the power supply. if the buzzing stops than its the pannel boards otherwise its supply.
Dec 05, 2008 | Televison & Video
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
Screen off and sound buzzing
Probably a bad high voltage transformer and horizontal output transistor.
Jan 21, 2007 | GE 35GT720 35" TV
Toshiba 56HMX195 52" HDTV DLP Projection TV Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
