Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
I have a 25cc homelite weed trimmer.... the fuel line is loose in the fuel tank... how do i get it back in
    Scholar:
  • 71 Answers
You will need the correct size fuel line first. Follow this:
1. Remove the old filter/weight from the fuel tank.
2. Take a new fuel line piece about 8 inches long and cut about a 45 degree angle cut on one end.
3. Lightly moisten the cut end of the fuel line and insert it into the tank from the outside, pushing it in while turning as far as possible.
4. Use a needle nose plyers to reach in and pull the line to the fuel line cap. Cut the line and replace the filter.
5. Pull the line back the way you put it in leaving about 4 inches within the tank and re-attach to the carburetor or primer bulb (depending on the actual model/age)
It will work, but it is extreemly important to have the correct size fuel line to work with.
Posted on Sep 27, 2010
  • waydea Apr 02, 2011
    Thank you. I have been searching this question for days. My tank filter fell out and I did know if I needed a new tank or if I could just get a new hose, Is a garrmot necessary? Who thought of this design, anyways!
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
How fuel hoses instal model UT22546A Homelite weed eater
Hi Armando
I believe this is what your looking for.
Please take time to rate me
Bud
Oct 28, 2012 | Craftsman 25cc Gas Line Trimmer
ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
How to get new plastic fuel lines in fuel tank in my weed-eater hedge trimmer. the line is larger than the hole in the tank.
Oftentimes it helps to use scissors to trim back a portion of the new line. Start at the bottom and cut upwards at an angle. Put some lubricant (WD40, perhaps) on the line and slide the sharp point into the fuel tank. Using needle nose pliers, grab the line and pull it through. This will only work if you have the correct size line. If the new line you are using is too large, you probably can't pull it through.
Apr 20, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
715 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
