Question about Magic Chef CTF2125 Top Freezer Refrigerator
Water is running down from center of back wall & puddling in bottom eventually running out at the front making the floor wet on ctf2125 model Kevin
  • Magic Chef Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ww
Posted on Sep 27, 2010
True commercial cooler model GDM-49-LD. Been fine for several years. Water now accumulating in cooler floor. Origin seems to be back wall dead center. Any suggestions ?
drain tube runs from dead center of the coil into the back wall and down under the unit where it drains into a pan and is evaporated. Sounds like just a blocked drain tube. The easiest way to clear this is to take the bottom front grill off and look for the drain tube which is typically just strapped to the top of the opening suspended over the pan. Use a wet vac to pull out the sludge or some kind of pressure to blow it back up into the cabinet. Problem with blowing back is that dirt and water are going to blow into the cabinet and/or coil. taking the hose off of the interior coil is difficult and you can break the plastic connector so I don't recommend that to anyone.
Sep 04, 2014 | True 49 cu. ft. / 1388 liter Commercial...
TPX24BRBC
On GE's site they have the following.
Side by side refrigerators:
The usual evidence of a clogged drain in a side by side is the discovery of ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor when it runs out the freezer door. Some side-by-side models have the defrost drain hole located on the back wall of the freezer, just up from where the floor slopes up to the back, in the center. In some models it is behind a plastic panel held in place by a screw. Remove screw and panel, and the drain hole will be visible.
Flush out the drain hole with a solution of 1 tsp. baking soda and 2 cups of hot tap water in a meat/turkey (bulb) baster. When clear, you will hear water running down into the drain pan below.
A Whirlpool Master Tech replied to a similar question on their site with the following.
"You will need to remove everything from the freezer and then remove the rear interior wall to gain access to the drain hole ."
Jun 13, 2014 | GE Refrigerators
There is a huge puddle of water under the front of the fridge ,this unit doesn't have an ice maker what could this be ?
The drain is clogged. You will have to remove the back wall of the freezer to access the drain. There is a hole under the coils, that is th drain. Remove the ice on top of the drain and clean the drain out by forcing hot water down the drain with a turkey baser untill water flows freely. Then mix baking soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 28, 2010 | Magic Chef CTF2125 Top Freezer...
The defrost cycle seems to stay on too long-ice already made will start melting & then refreeze into 1 big chunk. Eventually the "melt" will build up in the bottom of the freezer & will eventually...
if think your defrost cycle is ok . there is a defrost terminator that controls the heater at 50 deg in the back of freezer , the problem is the water delivery tube is iceing oven and causing water to run down the back of freezer wall . change the tube to newer style. it will be open on the top side . they work better. and the water valve may be leaking through. and may have to be changed .. ,,
Jul 29, 2010 | Refrigerators
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
Wall a/c is leaking water down log wall and puddling on floor.
When you sealed the holes outside, you trapped the water inside. The unit is designed to let the water run to the bottom of the pan and then go out the holes outside. Try unplugging one of them and see if that fixes the problem. Hope this helps.
Jun 24, 2009 | Emerson Heating & Cooling
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water coming out freezer door
Replace the defrost heater thermostat in back of freezer wall.You can reach it from the open front freezer area.Just take loose the back wall plate(s).Youll see it (maybe under alot of ice)clipped onto heater coil.You should be ok now. Please leave a rating!!
Jun 07, 2008 | Refrigerators
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Magic Chef CTF2125 Top Freezer Refrigerator Logo
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
