Question about GE GSS20IEP Side by Side Refrigerator
I am trying to locate where the evaporator is on my GE side by side Model #GSS20IEMBWW
  • 58 Answers
Behind the lower panel in the back of your freezer. Should be four screws to remove panel
Posted on Sep 27, 2010
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: I have a GE side-by-side model GSS20IEMBWW.Freezer
Do you hear the freezer fan working when you push in the light switch manually ? If not , then probably bad main control board (99% chance ) Pt # WR55X10656 . If you do hear the fan , then probably (90% chance ) the defrost heater is bad . Pt # WR51X10101 .
Posted on Aug 07, 2009
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
Gss20iembww
Find the light switch and make sure its not stuck, otherwise make sure the bulb is good.
Oct 26, 2013 | GE GSS20IEM Side by Side Refrigerator
No water is dispensing on GE model GSS20IEMBWW.
remove the kickplate you should see a quick disconnect at the bottom. disconnect it and then hold a cup under it and call for water. If you have water to that point your line is frozen through the door. You will need to shut it down w/ the door open for 24 hrs to let it thaw. GE didnt insulate their doors well. MJ
Mar 18, 2010 | GE Refrigerators
GE Model # GSS20IEMBWW Refrigerator is making a vibrating sound in the back that stops when I open either door, but as soon as the door is closed, the noise starts back. Also, there is a lot of frost in my...
the inside fan that blows air from freezer to fridge side located on back wall either stuck has build up of ice or some debris is stopping or slowing it down open freezer door and look at back for fan remove cover and or frost covering hold door switch and look and listen to fan if labors or just hums remove and service or replace
Oct 14, 2009 | GE Refrigerators
I have a GE side-by-side model GSS20IEMBWW.Freezer very cold,but refrigerator hot.Checked evaporator coil and it was iced over
Aug 07, 2009 | Refrigerators
GE gss20iembww wont end defrost cycle
yes replace heater tstat and back board
Mar 17, 2009 | Refrigerators
I have a G.E side by side refrigerator model #gss20iembww. The problem is it isn't cooling anything down, it just stopped, last night it was fine, today everything is warm. The light is on inside the unit,...
YOU MAY NEED A NEW FILTER. CHECK ON THE UPPER PART OF REFRIG. IF COOLING PROPERLY-IT SHOULD BE GREEN IF RED OR ORANGE YOU MAY NEED A NEW FILTER. WE BOUGHT OURS AT AN APPLIANCE STORE AND INSTALLED IT OURSELVES.
Sep 13, 2008 | GE Refrigerators
GE GSS20IEP Side by Side Refrigerator Logo
91 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
