Question about Dishwashers
A knife with a plastic end must have fallen down during a cycle and melted to the heating coils of the dishwasher. Could not get it to come off at all! Then unfortunately we forgot and did another load. Obviously it has melted further and still wont come off. I'm not sure what to do? Thank you!
  • 4,349 Answers
WEll, it will take heat to get this plastic off. nothing else works.I would use a heat shield, gas torch and a wet terry cloth towel. heat the unit up and pull off with the damp towel. Really nothing else works. Sometimes you can activate the burner, but that is difficult to do during this process.
Posted on Sep 27, 2010
Heater on hot air regardless of settings
Without knowing the make and model of your car, this is a general answer. Check for a vacuum hose that has fallen off the engine. Sometimes, the small diameter plastic hoses develop cracks that are hard to see. If you find one that has melted from excessive heat you can repair them easily by taking a very sharp knife to score the diameter then bend the end to snap off the damaged part. Cutting it with wire cutters will only crush it and cause more cracks. Once you have prepared the ends of the tube use a rubber vacuum hose section to join the plastic tubes together.
Jul 23, 2016 | Cars & Trucks
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
Burnt plastic smell (per tenent) during dry cycle. I saw no melted parts on heating coil. Where to look next?
Hello Jon, thank you for your post!
Based off what you have described the Frigidaire dishwasher is giving off a burnt smell. You may need to check under the dishwasher to verify all the components are in proper working order. The element may have touched the tub or spray arm and this may have caused the smell. I would suggest having a professional technician out to your home for proper diagnosis and repair. Hopefully this information is helpful to you. -Matt
Feb 16, 2016 | Frigidaire FPHD2491KF Dishwasher
A plastic lid melted on the coil, still smells like "melted wax", seems clean, what can I do?
You will probably have to replace the heating coil in the bottom of the dishwasher to get rid of the smell. The coils aren't that expensive and replacing them is an easy job. Hardest part is getting the dishwasher out from under the counter to do it.
Feb 19, 2014 | Whirlpool Dishwashers
KitchenAid dishwasher model: KUDI01FLSS caught on fire during a cycle! Wife claims she heard "electrical" sounding popping and crackling and smoke was pouring out sides. She was able to...
Sorry to read about your problem, I hope this helps you out.
yes you should replace, i would guess the plastic is melted, in the coil area
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Dishwashers
The Plastic Dishwasher Flatware Baskets Being ''Eaten/Melted''
Check to see if the electricity supplied to the drying elements is connected at the back of the dishwasher. If so, this would be the hottest spot in the dishwasher during the dry cycle. Most dishwashers have the flatware baskets located on the sides; not the front because of conflict with the detergent holder, or the back because of higher heat or (on newer models) a power scrubbing feature. See if you can put the flatware baskets on the sides. This should help.
In any case, the baskets should not be melting wherever they are located. This could be fire hazard.
Oct 24, 2017 | Kenmore Dishwashers
The cycle did not complete,the bottom spray arm (the tip) melted along with some plastic utensils (knife handles). Water come out of thee front door.When starting the washer again, the top and bottom spays...
The handles slipped down keeping the spray arm from rotating thus causing it to rest against the heating element. It won't wash because of the hole in the bottom spray arm. You have to replace the spray arm before nything else can be determined.
Feb 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Lid melted on bottom heating unit -
I just took a knife adn scraped off the heaviest and ran the dishwasher again. When it was complete I scraped some more while it was soft. Most of the plastic is gone now.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Kenmore Model 665.15891791 Dishwasher
Tim, start with the vent itself. Sometimes these vents get clogged with gunk and will not let the hot air escape. After that you will have to do some testing. Your model should have a safety thermostat that opens if the temp inside the dishwasher gets too hot cutting power to the heater. If your dishwasher has a heated dry selection you want to make sure that pad is working. You would have to select air dry, and see if the heater is getting power with a meter during the drying period. If so, you probably have a welded relay on the board. Catriver...post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
