Question about Dell Studio 15 Laptop
Have a Dell Studio. When I power up the Dell Logo appears with loading bar below that. The bar stops about 2/3 of the way, it freezes up and starts beeping. Nothing I've tried works.
  • Dell Master
  • 629 Answers
This is often related to a possible motherboard problem. Try these steps: turn it off, remove the battery, and AC adapter, then press and hold the power button for about 5 to 10 seconds. Once done, reconnect at least the adapter , turn on the laptop and as soon as the Dell logo shows up, tap F2 a few times to enter System Setup (BIOS screen). From there, go to the Maintenance category, and select Load Defaults, press Enter. Press ESC, then select Save/Exit, restart the computer and see how it goes.
Posted on Sep 27, 2010
My laptop loads about half way and stops
Sounds like you have a problem with the OS (Operating System Software) loading. Either your OS is corrupted or your computer is having a problem detecting your hard drive. You did not specify what model Studio you have. Here is a link to Dell products:
http://www.dell.com/support/troubleshooting/us/en/19/ProductSelector/Select/FamilySelection?CategoryPath=all-products%2Fesuprt_laptop%2Fesuprt_studio_laptop&Family=Studio&DisplayCrumbs=Product%2BType%40%2CLaptops%40%2CStudio&rquery=na&sokey=solink
Feb 06, 2013 | Dell Studio 15 Laptop
After switch on button activation Dell logo appears with load progress bar stopping 1/2 way and screen freezes. The F2 and F12 buttons options at bottom right of the screen do not respond. Tried using...
The first check you could make is if every component is correctly plugged.
When the pc starts it makes a control of all components before booting. You may want to check also internal components.
For this reason is also useful to know if when the pc starts it does only one "beep" or a "beep code" (for instance one long and one short "beep" or two long "beeps" ecc)
If everything is correctly plugged it may be a motherboard problem.
Let us know if you solved your problem
Aug 21, 2011 | Dell Studio One 19 PC Desktop
How do i factory reset my dell studio 1537? its asking for user 2 ...name and password.....what is this??
turn off completely, power it on and as soon as the dell logo appears hold down the control(Ctrl) key and simultaneously hit the F11 key(repeatedly). The factory reset screen should come up. You will loose all data plus any programs that were added. If this does not work try the instructions on the link below. Just copy and paste. http://www.lancelhoff.com/restore-dell-studio-to-factory-settings/
Aug 19, 2011 | Dell Studio 1537 Laptop
Studio 17 laptop stalled during uploading of a music cd into ITune libray. Manual shut down and reboot resulted in stalling of reboot process at 3/4 of the status bar with only the dell logo on black...
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 16, 2011 | Dell Studio 17 Laptop
Hi. i have a dell optiplex gx620 with boot broblem, the computer just stop when start it , the dell logo appear and freez, the indicator reach 30%. even i can not enter to the bios (f2) or do any thing, i...
Freezing during the Power On Self Test (POST) is typically due to hardware problems. You can narrow down the culprit by disconnecting devices one by one until it boots clean. Start with the CDROM, then the floppy, then any cards.
Apr 30, 2011 | Dell OptiPlex GX620 PC Desktop
POWERS UP BUT THEN FREEZES AFTER ABOUT 4 MINUTES
Need to test and isolate where it exactly freezes? After dell logo, after windows logo or while inside windows? Now, if it only freezes inside windows try to turn off your windows updates and antivirus first and check if still freezes, if yes then try booting in safe mode, reboot system then keep tapping on f8 once dell logo appears. Check if laptop keeps freezing in safe mode. Please let me know.
Oct 01, 2009 | Dell LATITUDE C600 PIII 750MHZ 128MB 15GB...
Computer not starting up
Try Cleaning Ram Fingers with rubber and re inserting could be a bit of corrosion or moisture/fluff this often works
Feb 01, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Studio 15 Laptop Logo
194 people viewed this question
Alun Cox
