Question about Microsoft Zune JS8-00001 Digital Media Player
Problems with zune
Sometimes when i tune the zune on it works for about ten min.and then it tunes off by itslef. it does it for about three time before it works ok. any idea whats going on?(i got the black 30gb)
  • ksample19 Aug 15, 2008
    when i turn my zune on it just say to start visit www.zune.net/setup.what do i need to do.
  • 8,596 Answers
Check the menu settings and see if the sleep mode has been activated - turn off.
Posted on May 26, 2008
1986 Mercury Grand Marquis. done everything internet to read the check engine codes. Check engine light comes on and runs rough when I floor it and stays on until the car sits for about ten mins.
A complete tune-up is a much misused and misunderstood terminology that means many things to many different people - in short it says very little and usually means very little.
I suggest you begin by checking the exact function of the "check engine light" in the vehicle handbook. At that time the engine management system (obd 1) was quite limited and although obd 2 scanners will sometimes partly read obd1, mostly a dedicated scanner is required. Sometimes there is a self-diagnosis system that can be triggered by shorting certain pins of the diagnostic socket.
The check engine light might be concerned less with electronic faults and more with detecting excessive exhaust emissions. It is also worth noting the early electronic control units weren't as robust or sophisticated as today's units and they could be easily damaged by jump starting, battery boosting or welding or alternator regulator failure resulting in an overcharge situation, but such damage often didn't become obvious for a significant time afterwards; months or even years. Such damage sometimes resulted in failure but sometimes in erratic behaviour or amnesia or the self diagnosis telling lies.
This can only be realised by using diagnostic equipment to read live data to verify any fault codes and by the independent testing of sensors and actuators and by using sensor simulators.
I suggest you also carry out an early fuel pressure and regulator check and then ensure the injectors are spraying properly and not dribbling.
An essential part of a complete tune-up is a physical check of the spark quality and power and if that hasn't already been done I suggest you do this.
Aug 18, 2016 | Mercury Grand Marquis Cars & Trucks
Just did tune on 1994 chevy impala and now the pass key fault light flashs and car want start
Relearn procedure--- Turn the key on for ten minutes, turn it off for five seconds. do this three times and after the third time it should start. Just a note... Put a battery charger on it as this procedure will drain the battery.
May 22, 2011 | 1994 Chevrolet Impala
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
I have a zune ipod and want to download music from my itunes to my ipod everything i try dose not work
You must use Windows Media Player to download to your Zune...I tunes only works with Ipods.
Oct 13, 2010 | Microsoft Zune JS8-00001 Digital Media...
Need set up my zune serial number is 082256563710
you need to download the zune software from microsoft. I believe it is called zune marketplace. The interface is a little cumbersome but straight forward enough. Zune's will not work on Windows Media Player. Microsoft is trying to compete with I-tunes on this with their Zune marketplace. Like I said a lot of flash on it but not a lot of substance with the software, but you have to use it to get your media on your player.
hope this helps
Oct 17, 2009 | Microsoft Audio Players & Recorders
Sony DVP-NS55P dvd player i am having trouble with it playing any disc it will say loading for 2 min then display cannot play, i have opened the unit up cleaned the lens multipul times, sometimes it will...
Your optical lens needs a tune up or it has reached its maximum shooting power. Send ur unit for tune up, if still same then its time for a new lens.
Jul 05, 2009 | Sony DVP-NS715P DVD Player
Zune 30gb froze
mine did the SAME THING!!!!!! ahhh what will i do without my tunes!
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune has a power problem
pleas,help me!
my zune it has power on but no boot hardish.it tune on then shut down.can you help me pleas
Apr 14, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
23 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
