Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
I have a yamaha v-565...all of a sudden it is not feeding video and audio to HDMI (TV) is intemittedly cutting out....HELP...
I am having the same problem.
Posted on Feb 02, 2011
I suddenly get audio but no video through all hdmi inputs
If you have you video componenets patched through the reciever, then to TV, this can happen. The reciever can transfer video but, it more connections, not as effiecient, and, leaves more room for error. Your video componenets should be run directly to TV, if you TV has the inputs, via HDMI, component, or RCA the, run a single output, best, digital optical out from TV to reciever. You can use the TV's menu to choose what you are watching and, only have the one audio output from TV to reciever. You would leave the reciever at the same, Aux, Vid 2, selection all the time. You will get your best picture and best audio this way.
Jun 13, 2011 | Yamaha RX-V665 Receiver
Yamaha RX V992, HDMI 2 mode
tell toshiba dvd 720 p only and use bitstream outsetting in audio of dvd player ok if that dont do it run dvd directto tv then digita opti cable from tv back to sterio ok
Jan 21, 2008 | Yamaha RX-V992
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Feb 18, 2010 | Yamaha RX-V596 Receiver
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
My Yamaha receiver model rx-v565 audio is putting out choppy sounds when cable is playing. I am using all HDMI connections. My TV is an LG 240 Hertz model and using the comcast HDMI box.
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Sep 26, 2009 | Yamaha Rx-v565 Receiver
Yamaha V-565 HDMI Video not working; Audio is fine. Video worked yesterday.
Sometimes the hdmi select can get switched go into the menu and switch it to the correct postion.
Jul 13, 2009 | Yamaha RX-V663 Receiver
No audio through hdmi cables from tv...Please help!
this is a relative defect:
the HDMI connector can hold digital audio but analog audio cannot be decoded in this step. HDMI most of the time has a couple of connectors besides it that it is a couple of regular RCA connectors right and left channels. has to be connected to listen this kind of audio. some signals in now days are totally digital but still some signals that have regular analog audio (as the old fashion days)
Apr 15, 2009 | Televison & Video
HDMI SOUND PROBLEMS
yes u guys nee dto do all the hdmi directto tv then optcal digital back to sterio digital in for sound only ect not throw sterio kills picture also
Jan 30, 2008 | Yamaha RX-V661 Receiver
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
96 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
