Question about Ricoh Office Equipment & Supplies
Service code 391 on a aficio mp 171. how to fix it.
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
20YrsCompExp
  • 227 Answers
SOURCE: How to get into ''service mode'' on Ricoh Aficio MP 2238c
There are MANY things to screw up in SP mode. I agree with sandmanmac. List what you want to accomplish and maybe we can help!!!!
Posted on Mar 28, 2009
Matt_Sr
  • 31 Answers
SOURCE: I bought a brand new
Jeez, the MP171 is so new I haven't even had a service call on one yet, it's pretty much identicle to the 161 though. One of the biggest problems I've seen with the bypass trays is having them set at a static paper size and then running a different size other than what you've entered. Your symptoms match that of paper jam caused by timing error, being that the bypass utilizes the main body for the bulk of the feed cycle and your main drawer works, I would double check what size you've got programmed in for the bypass.
Posted on Jul 26, 2009
  • 68 Answers
SOURCE: Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
Posted on Sep 16, 2009
Was this ever fixed, I just got the same error?
Posted on Jan 06, 2010
How to empty ricoh mp171 waste toner
mp 171 has no waste toner container. it recalculates toner back to developer section.
Mar 20, 2017 | Ricoh Aficio Mp 171 Spf Copier,...
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
How can I fix my copier that tell me to see instructions in the right corner to remove?
Check it properly there will small paper will be there other wise the sensor will be dirt.
Feb 27, 2016 | Ricoh Aficio Mp 171 Copier
Is there a specific type of oil used for the rollers
open Tray 1. Remove the paper feed roller. Remove the separation pad under the feed roller. You will see a small spring. Try to cut JUST ONE ring of this spring.
Aug 07, 2014 | Ricoh Aficio Mp 171 Copier
How do i stop the roller in the paper feed from making noise?
Lubricate the shaft of the roller. Clean the roller and friction pad. Usually that helps.
What is the error code 391?
This link may give you more incite on your error code problem
May 08, 2014 | Ricoh Aficio Mp 2000 Copy Machine
@wAm getting a sc 302 code on a gestetner mp 171.I have changed the whole drum unit.
Hello!
When you change the PCU did you conect the blue plug????
If this is not the case remove the PCU again and if you look deep down you will see a metalic shaft. Clean it and install again the PCU.
Hope this helps you
Aug 01, 2011 | Ricoh Aficio 2015 Copier
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
313 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
