Question about HP Photosmart 2575 All-In-One InkJet Printer
Black line along page in copy and scan modes,not in print mode
I've cleaned nozzles 3 times.Problem still remains.Any ideas?Thank you.
  • BUYER7755 May 23, 2008
    Thank you very much.I will try it.Catch u later!!!!!!
  • Anonymous Nov 09, 2008
    Black line along page in copy and scan modes,not in print mode problem, and notify you when a new solution is offered.
  • 55 Answers
Your scanner lamp is dirty. Take apart the scanner glass and clean the lamp. (Look for contaminated spots on the scanner lamp).
Posted on May 23, 2008
Hello there , my question is ok- when i Print or Copy there is more over tone of yellow exampel if it is- RED it comes out YELLOW - and( no) i do not have the( yellow) in the( red )container It...
You'll have to run the cleaning mode a few times,
to do so you'll have to get into Maintenance Mode.
To do this:
Press MENU then * then 2 then 8 then 6 then 4
This takes some practice and you have to press them all within a few seconds.
If the machine doesn't say MAINTENANCE when you do it press STOP/EXIT and try again.
When in Maintenance Mode:
Press 7 then 6, then press 3, then press BLACK START
It will say Cleaning - this will take some time when it's done it will go back to MAINTENANCE
After it's completed try 0 then 9, this will print out a small Print Quality test page
it should have several rows of each color (Cyan, Magenta, Yellow and Black)
if they still don't look right then run the cleaning mode again and then print another quality page.
Continue to do this until the quality is back to normal,
when you're done to exit maintenance mode press 9 then 9 to return to normal operation.
note: this cleaning mode uses up a fair amount of ink, use sparingly
note: maintenance mode is for brother technicians and has some codes that can damage your machine, only use the codes I've explained in this solution
Jun 05, 2011 | Brother MFC-260C All-In-One InkJet Printer
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Please telme how can clean the nozell of a stylus cx6400
Please perform the following steps to ensure your printer is physically functioning.
1) Disconnect the printer cable that is connecting printer to the computer.
2) Turn the printer ON by holding down the POWER button for about 3 seconds.
3) Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4) Press the green button next to the LCD screen until you see NOZZLE CHECK is displayed, then press the COLOR button to print the nozzle check.
5) The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6) To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the nozzle check pattern page doesn't print or if it prints with gaps or missing sections, the print head may need cleaning or the ink cartridge(s) may need to be replaced.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Jul 06, 2010 | Epson Stylus CX6400 All-In-One InkJet...
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Bold lines on Fax and Scan
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark X7550 InkJet Printer
Skipping while printing
STEP: Disconnect and Reconnect the Printer Power Supply
Additional Information
1.
Unplug the power cord from the wall socket.
2.
Disconnect the power supply from the back of the printer.
3.
Wait 15 seconds.
4.
Reconnect the power supply to the back of the printer.
5.
Plug the power cord back into the wall socket.
STEP: Perform a nozzle clean on the printer.
The following steps will guide you through running a nozzle clean on the 922 printer:
1. Press the Scan Button and the Up Button at the same time to enter diagnostic mode.
2. Use the Up Button or Down Button to navigate to Clean on the LCD and press Menu to begin the nozzle clean.
3. Check the nozzle clean printout and make sure that it is clear of defects and that all expected color bars exist on the page.
STEP: Clear NVRAM on the 922 Printer
1.
2.
Use the Up Button or the Down Button to navigate to the option for Clear NVRAM on the LCD and press Menu to confirm.
3.
Press Menu again when asked if you are sure.
4.
Press Menu again when asked if you are really sure.
Ink Cartridge and Print Quality Issues on Inkjet Printer
STEP: Verify the Paper Settings and Change the Quality Level
1. Click the Start button, point to Control Panel, and then click the Printers and Other Hardware menu item.
2. Click the Printers and Faxes menu item.
3. Right-click the Dell AIO Printer Model Number icon, where Model Number is the model of the printer to troubleshoot.
4. Click the Properties menu and the Printing Preferences menu option.
5. Click the Quality/Copies tab.
6. Click the Paper Setup button.
7. Choose the appropriate paper type based on what is being used in the printer.
STEP: Verify the Printer Ink Levels
Quality problems are most often caused by low ink levels or one or more colors in the color cartridge being completely depleted. Perform the following steps to determine the current ink levels and to check for missing colors.
1. Click the Start button, point to All Programs, and then click Dell Printers.
2. Click the model number of your Dell printer.
3. Click Dell Printer Solution Center.
4. On the main window of the solution center you will see two ink tanks in the lower right hand corner. Verify that the ink cartridges are not empty
To ensure that the quality problem is not caused by one color missing print a test page and verify that the colors in the CMYK boxes appear correct. To do so, perform the following actions from the solution center window:
1. Click the Maintenance button on the left-hand side of the window.
2. Click Print Test Page.
3. Verify that the Cyan, Magenta, Yellow, and blacK colors are printing without streaks.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
It says
I'm sorry you are having problems with your Lexmark printer.
Please ensure you are using the correct cartridge.
X3350:
Black 32
Color 33
X5470
Black:28
Color: 29
If you are using the correct cartridge for your machine you can try to do the following:
Cleaning the print nozzles: (X5470)
1 Load plain paper.
2 Press Copy Mode.
3 Press .
4 Press or repeatedly until Tools appears.
5 Press .
6 Press or repeatedly until Maintenance appears.
7 Press .
8 Press or repeatedly until Clean Cartridges appears.
9 Press .
A page prints, forcing ink through the print cartridge nozzles to clean them.
10 Print the document again to verify that the print quality has improved.
11 If print quality has not improved, try cleaning the nozzles up to two more times.
Wiping the print cartridge nozzles and contacts:
1 Remove the print cartridges.
2 Dampen a clean, lint-free cloth with water.
3 Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown.
4 Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and
5 With another clean section of the cloth, repeat step 3 and step 4.
6 Let the nozzles and contacts dry completely.
7 Reinsert the print cartridges.
8 Print the document again.
9 If the print quality does not improve, clean the print nozzles. For more information, see “Cleaning the print
cartridge nozzles” on page 92.
10 Repeat step 9 up to two more times.
11 If print quality is still not satisfactory, replace the print cartridges.
If you are still getting the incorrect cartridge message it would be best to return the cartridge and exchange it for a new one.
Thanks
Catherine
Mar 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
Black ink
You may want to do the ff. just to make sure your printer is physically functioning.
1. Disconnect the printer cable that is connecting printer to the computer.
2. Turn the printer ON by holding down the POWER button for about 3 seconds.
3. Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4. Press the Up or Down arrows to select NOZZLE CHECK. Press the OK button,
then press OK to print a nozzle check.
5. The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6. To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the Nozzle Check Pattern page does not print, prints out with gaps in it or some of the colors do no appear, then there is an issue with the printer. That means that troubleshooting is required on the printer prior to using printer on the computer.
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
according to the manual, goodluck!!!
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
459 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
