Question about Whirlpool Dryers
Dryer has power and will make ticking sound when you turn it to run and nothing happens when you press the start button.
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 27, 2010
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer won't start
IT SOUNDS TO ME AS IF YOU HAVE A BAD DOOR SWITCH. YOU CAN TRY JUMPING THE SWITCH OUT TEMPORARILY JUST TO SEE IF THE UNIT RUNS.
Mar 07, 2009 | Roper REX4634KQ Electric Dryer
Kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Jan 04, 2009 | Maytag HYE3657A Electric Dryer
Kenmore 90 series won't start timer ticks
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Faulty Start Button?
If the dryer doesn't even start to turn when you press the start button, then you have to look at a couple things; The start button itself, the starting relay or the safety circuit. You mentioned that there's a ticking sound... if this sound goes away when you open the dryer door but comes back again when the door is closed, then the safety circuit is working.
It could be the switch itself or the starting relay (if equipped with one). If you're mechanically capable, consider looking at the relay. See if the contacts are being pulled in when the start switch is pressed (DANGER: HIGH VOLTAGE). If it is, the start switch is OK.
Hope this helps.
Apr 02, 2008 | Dryers
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
