Question about Samsung HP-R5072 50 in. Plasma HDTV
PC to TV Audio Connection
How do you connect a MacBooks audio out put into Plasma or LCD Samsung TV?  What is the right chord, I have a Stereo Audio Y Cable, but it isn't working, What kind of chord is it that plugs into the PC input on the TV?
  • birdisthewrd May 23, 2008
    Yea I got the Video to work with VGA chord but it's the audio I'm having difficulties with.
    Guru:
  • 1,463 Answers
Hi
have a look here see if this helps you How to connect your Laptop/PC/Computer to your TV
riz
Posted on May 23, 2008
How to connect Hi-sense plasma television to dell windows 8 laptop? Can Hdmcable be connected if not what are the other options?
Computer HDMI ports don't usually pass the sound from the computer on the cable. You have to use a cable between the PC and the PC audio IN connection on the TV. This is usually a 3.5 mm stereo audio cable.
Sep 13, 2014 | Hisense TA42P40M 42 in. Plasma Television
Can't get sound to work with RBG cable from PC to TV
Sound will not work with mere RGB connection. The audio out of the PC should be conected to Audio in socket to TV.
May 02, 2012 | LG 50 50PZ950 50 3D Plasma TV
I want to know how to connect my lcd 32" tv to my new ht-c550 so that i can watch tv and listen to the sound of the tv through the surround system, what do i need to plug and where?
Not enough info here. But basically, the Audio Out from your TV (could be Toslink fiber-optic or Digital Coax or just Red and White Audio cables) go into the receiver's inputs (either TV, or Aux or whatever). If you just use the Red and White cables (stereo), you will not get true surround sound though. Just put your receiver on whichever one you hook it to (ie: Aux) and whatever sound is on the TV will come out the Stereo or Surround Sound. It's all a matter of hooking TV out to Stereo IN. Hope this helps; James
Apr 17, 2011 | Samsung Audio Players & Recorders
No sound on my DVD. Using S connector or jacks. Swapped DVD player, checked the cable connections, went through the menus on both the player and the TV. Never was a problem before.
hi,
if you are connected the S video output of ur dvd to ur tvs s video input , the u should connect another two RCA cable fo audio.S video connection is only for video input. connect the audio out put of ur dvd to the corresponding S video audio input, using a stereo RCA chord.
ok.
Dec 21, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a memorex dvd player and a dynex 32" lcd hdtv. I have all the cord correctly in the component plugs but the picture is black and white and there is no sound.
HI,
i think ur component video connection may inter changed. check it. are u connected red to red, green to green an blue to blue. if interchanged the picture will be black and white. also check the video system of ur tv and dvd.
about audio. for that u need a stereo rca chord. connect the audio output of ur dvd to the component audio input of ur tv. if u have already connected the audio cable , check the audio setup of ur dvd. there is selection for pcm audio select it and then check again.
ok
Dec 15, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
Hi there i am trying to connect a samsung lcd monitor to my pc via HDMI. i have the connection showing picture on my tv, however where i connect a 3.5mm jack from pc to tv no sound comes out. i have...
The connection to your tv is video only. You should hear sound coming from computer speakers. Unplug them and hook your stereo to that plug in.
Oct 04, 2009 | Computers & Internet
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
We have a samsung plasma 650 and a samsung htz510 We are not getting any sound thru surround system while in tv mode
Have you turned the TV speakers off within your Audio setup and turned on you external speakers? Your 510 then becomes your speakers. Also eliminates potential for audio synch issues. This done mean you have to turn both the TV and Audio system on everytime you want to "TV" programs. Good luck.
Jan 30, 2009 | Samsung HTZ-510 Theater System
LG Plasma 42PC56 optical digital audio out
I can't imagine your setup. Box, tv and pc speakers?
Typical setup would be box, tv and some kind audio system with optical IN. Correct wiring would be connect box to tv via scart and connect optical cable from BOX to audio system. You have to go from box not from TV since scart connection doesn't carry audio signal. To have TV to output optical audio out you would have to connect it to box via hdmi.
Dec 02, 2017 | Televison & Video
Samsung HP-R5072 50 in. Plasma HDTV Logo
153 people viewed this question
Henry  Thomas
Henry Thomas
