Question about Polaroid FLM-3734B 37 in. LCD HDTV
My TV screen just went black, i have had some problems with it freezing in the pass but i thought it was temporary. so tonight i was watching football and it just went black! so i was wondering if i could take it apart or something and maybe fix it, thank you so much! :) i really dont want to buy a new TV
  • 192 Answers
This solution is for a Polaroid flm-373B 37 inch LCD TV. I noticed your TV is the flm-3734B. Hopefully this solution will work for you too.
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my flm 373B with 25V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Sep 27, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Son sprayed cleaner on tv.
I have not a clue what to tell you, but doubt the cleaner is the cause of this. In any case the TV is so old you will not be able to get parts.
Jul 09, 2017 | Televison & Video
Was playing Super Smash Brothers, played 1 5 stock 1v1v1v1 against 3 computers, then went and started a second round. It lasted for about a minute or 2 and then it locked up... i hit the reset button, and...
Well I think that the expansion pack has died I had a problem while I was in the middle of perfect dark it would freeze and then 2 seconds later the screen went black and than it went to the tv screen saying no signal. the expansion packs make it look like it died but it didn't.
Nov 01, 2010 | Nintendo 64 Console
32" flat screen that went black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Element Electronics FLX3210 32 in. LCD TV
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
42px5d got sound but no picture
You need the Y sustain and y drive boards. No idea where to purchase in australia, but you may be able to order them from LG.
Jun 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Problem with proscan 19LA25Q
Watching a movie tonight...and slowly there was odd behavior from the screen. No volume at first, then flickering, fragmenting and now, as the others only shows the red power. I have noticed some strange flickering the past 2 weeks or so. I thought it may be the cable, so did not concern myself too much. I believed that was the problem tonight as well. But the screen is definately not responding to the remote or manual button.
Thanks
Mar 16, 2008 | Proscan 19LA25Q 19 in. LCD Television
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
185 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
