Prblm with local discs
When am trying to open my local disk(all) its showing open and so am not able open straight forward
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    I am most sorry. I cannot understand, please rephrase. OK.
  • 74 Answers
U drive contain autorun.inf file delete it.
it can be hide
else go to run type gpedit.msc
user config
in that addminstrative template
in that system right side u found Turn off autoplay enable it
for more help call me +919441133420
kishore chowdary
Posted on May 24, 2008
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
My dvd player shows disk error when I am trying to watch a dvd. I opened it up to clean the lens on the laser and noticed that when I loaded the disk into the player it was not spinning. It does however...
If you have opened it up once then you can go ahead and open it again and power it up without a disc in it. You should see the laser beam light up and the laser move back and forward looking for the disc and the wheel spin and stutter as it looks for the disc. If you can't see the beam then its probably one of two things. The laser diode has burned out or the ribbon cable into the laser is out or not fully in the connector. IF you do see the laser beam then its most likely you have a dirty or broken drive band, (Black elastic band). Clean it or replace if broken. The last solution would be to replace the drive motor but Id doubt you will have to go that far.
Feb 26, 2011 | Televison & Video
Prblm with DVD-RW 4.7GB
Thank you for your question.
DVD-RW discs need to be formatted before use, similar to a Hard Drive.
I am presuming you have not used this disc before.
Locate your DVD Drive in My Computer or Windows Explorer, right click the icon, then select Format. It will say "Format Completed" or similar, then it is ready to accept data that you wish to "burn" to it.
Kind regards
Jun 01, 2010 | Imation 16575 2.4x DVD+RW Storage Media
MY INSTALLATION DISC FOR DIR-615 ROUTER IS DAMAGED
you dont need a disk to set up the router - you can set it all up via your PC the user manual for the dir-615 http://www.dlink.com/products/?pid=565 if you click on "support resources" button then choose your country
direct link here to UK http://www.dlink.co.uk/cs/Satellite?c=TechSupport_C&childpagename=DLinkEurope-GB%2FDLTechProduct&cid=1197319391320&p=1197318962293&packedargs=locale%3D1195806691854&pagename=DLinkEurope-GB%2FDLWrapper
The chances are that the default settings may work with your MODEM - but if not then the settings are straight forward
post a comment back on anything you dont understand
Mar 21, 2010 | Computers & Internet
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
Xbox won't play disc
Try blowing in the disk drive, or going to your local office supply store and by a pressurized air can. Make sure to follow the directions on the can, but basically spray pressurized air into the disk drive and see if this maybe cleans up any dust. You can also try purchasing a disc drive cleaner (a CD with brushes on it), this will also help clean off the laser.
Mar 18, 2009 | Microsoft Xbox 360 Console
Kenwood dv-505 door will not open
THERE IS AN EMERGENCY OPEN OPTION ON MOST ALL DISK DRIVES, LOOK RIGHT BELOW THE DRAWER USUALLY TO THE RIGHT FOR A SMALL PINHOLE. GET A PAPER CLIP AND STRAIGHTEN ONE END OUT, INSERT STRAIGHT INTO HOLE UINTIL YOU FEEL IT STOP AT THE MANUAL RELEASE CATCH AND GENTLY PRESS UNTIL YOU HEAR THE DRAWER BEGIN TO OPEN.
BLOW ANY DUST OUT, AND CHECK THE PC AND DRIVE WEBSITE FOR A POSSIBLE FLASH UPDATE FOR YOUR DRIVE MODEL. THEY ARE OFTEN POSTED WHEN DRIVES SHOW PROBLEMS READING SOME OF THE NEWER DISK BEING MADE. THIS HAS WORKED FOR ME A FEW TIMES IN THE PAST.
Feb 13, 2009 | Compaq Evo N610C Notebook
Stereo Problem
This unit needs to be dis-assembled and the CD loading mechanism rebuilt. While a relatively straight-forward repair, this is not something to be attempted by an unexperienced individual. There should be no parts required for this repair, just the local labor rate.
Dan
May 22, 2008 | RCA RS2650 Shelf System
Fast forward of Disk on my Go.Video2140
Try keeping pressed the skip button to do fast forward on a Disc.
Apr 22, 2008 | GoVideo Go Video DVD/VCR Combo
Local Disk(D:) is not accessible Access is denied
first u have format the c:drive the problem is solved
if not u should format all over the system
Feb 20, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
