Question about Toro Lawn Mower With Toro Power Tools
I have a '99 Toro HXL 15-38, everytime I lock the brake to get off and empty the bags the engine kills and backfires. Also backfires when I restart It. Seems like a safety switch problem. Any help would be appreciated!
  • 8 Answers
SOURCE: I have to prime the toro mower every time I empty
  1. what is the model, manufacturer and year of mower?
  2. has any maintenance been performed on this mower?
  3. if no, try replacing the spark plug and air filter (it's possible the spark plug could be fouled and/or the air filter is clogged) be sure to follow the manufacturers recommendations for oil, gas, filters and plugs.
routine maintenance involves:
  1. sharpen/replace blade
  2. oil change
  3. replace air filter
  4. replace spark plug
  5. new gas
Posted on Sep 03, 2009
  • 203 Answers
SOURCE: Replacement of Belt to mower deck on a Toro 17.38
Go to this website:
https://homeownersolutions.toro.com/portal/server.pt?open=512&objID=214&PageID=0&cached=true&mode=2&userID=19461
Type in 71243 in the search. You want to click on the red tab that says "manuals". Look for the english version, if that is your preference. Click on the red text and it will open up a .pdf with your operators manual. Think it was on page 33 that gave belt lace instructions.
Posted on Dec 04, 2009
  • 3 Answers
SOURCE: hy,i have toro ride on mower,model 71242,serial
You have accepted an Answer! From Ranwell1
Tuesday, January 04, 2011 12:42 AM EST
There are several things that can cause this problem. I will try to give you some ideas and then we can discuss each of them as you wish.
1. The brake someimes sticks on with this model. On the right hand side of the transmission (As you are standing behind the tractor) there is a small brake lever that is connected to the transmission and has the brake rod going from it to the brake pedal. Take this small lever that is on the transmission and pull it backwards toward you. If it is stuck, then it should release and the tractor should move. Most of the time you will have to spray some WD-40 on the brakes behind this lever and move the lever back and forth many times so it will not stick again. One of the reasons this happens is because the battery is usually located above this break and it corrodes. Another cause is that people tend to either wash the unit with water...which you should NEVER DO..... and it rusts solid and sticks.
2. The drive belt may have broken or has worn too much to operate the transmission. Replace the belt even if it looks fairly good if this is over 3 years old.
3. There is a transmission push/pull valve located in the back of the tractor. This is used so you will be able to push the tractor. If this is still in the PUSH position, then the tractor will not drive. Check this and move the lever back and forth several times to make sure that it is not stuck. Sometimes the lever on the transmission will stick and you will have to reach under the transmission and move the small lever itself to unstick it.
4. there is a keyway that is built into the main DOUBLE SHEEVE PULLEY that is located on the engine crankshaft. Many times the built-in key in this pulley will shear and cause the crankshaft to turn inside the pulley without turning the pulley and thus the transmission does not turn under load. If this is the case, you will have to replace this pulley.
5. If someone has taken off one of the wheels to thave a tire fixed, or fro any other reason, many times the key that holds the wheel to the axle slips out of place and the axle rotates inside the wheel without turning the wheel. this will cause the tractor not to move. Check the keys in both back wheels to make sure that they are in places and not sheared.
6. The transaxle itself may have gone bad and may need to be replaced. If this is the case and you have tried all of the other suggestions, I recommend that you take the entire unit to a GOOD Toro repair dealership and have them check it out. These units are sealed units and are not usually customer serviceable, but the dealer can check to make sure that it is not just low on oil. IF it is, then he can add the proper oil to it and it may work, if not, then the transmission will have to be replaced.
Ok, now that I have said all that, I think that TORO has a link on there website where you can download a service manual http://www.toro.com/
You MUST have the EXACT Model and serial number of the tractor. It is located under the seat of the tractor. If you input these numbers, you should be able to get a service manual for this unit.
I hope this helps you.
Posted on Jan 08, 2011
barterjoe
  • 344 Answers
SOURCE: Toro rider 16-38 HXL
Three options:
1. The carburetor throttle plate (closest to the engine is stuck); clean it with gumout and work it back and forth
2. the linkage is hooked in the wrong hole ; check the wear pattern on the throttle shaft plate to see if it is in the wrong hole.
3. The govenor arm or gear is not adjusted properly; loosten the govenor arm, push the throttle plate of the carburetor all the way closed. push the govenor arm the same direction all the way until it bottoms out. tighten the arm clamp. Test again
I recommend getting a manual or at least a free parts diagram from a local shop like www.arcolawn.com
Good luck
Joe
please vote me up if the fix was good.
Posted on Feb 12, 2011
vincob
  • 718 Answers
SOURCE: when i try to start the riding mower will only
Make sure your battery is in good condition first. Then if your machine is an OHV you might want check the intake and exhaust clearance. Go to smalleng.com and watch video they have a great tutorial on this subject. Good Luck...
Posted on Sep 27, 2011
Toro wheel horse XL series model 71212 / 17-44 hxl manual
Go to https://www.toro.com/en/parts and enter your model number 71212, it will give you choices for parts, operator, etc.
Apr 27, 2017 | Toro Garden
I have a Toro 14-38 HXL 71193 I need the part number for the Drive belt
The belt you are looking for should be number 18 on the diagram if you follow this link.
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
and the part number shows to be a 88-6280
Hope this helps
Aug 24, 2014 | Toro Garden
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
My 22" cut toro lawnmower with its 190cc Briggs & Stratton motor with automatic choke starts easily when cold and runs well. When you turn it off to empty the grass clippings bag, it will not restart...
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
Oct 05, 2010 | Toro Lawn Mower With Toro Power Tools
First start is excellent when cold, will not restart again warm
It sounds as if your engine may be getting too hot. I suggest that you check under the covers and make sure that all the debris is cleaned out. These are air cooled engines and as such need to be kept relatively clear of debris, especially anywhere there are cooling fins.
May 09, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Unable to restart Toro lawn mower after it backfired and stopped.
Did you hit something? Sounds to me like a flywheel key sheared off or a major internal part broke. My thoughts are you will need to take this to a repair shop or individual that can comfortably tear into the engine.
Oct 24, 2009 | Garden
15 38 hxl moves slowly, trans won't pull on incline
If the transmission whines, the brake may be sticking. you may have to relocate the brake return spring, to the rear of the flange that the spring is currently attached to
Aug 13, 2009 | Toro Lawn Mower With Toro Power Tools
Hello, my Toro 14-38 hxl (model 71193)is not
I have 12-38 hxl, and if my grass is too tall, it will wedge under the cutting deck and lock the blades, and the belt willstart smoking white. With the motor off look under and see if you do not have something stuck (branches or grass).Also, check your sparkplug.
Jun 05, 2009 | Toro Garden
Toro Lawn Mower With Toro Power Tools Logo
79 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
