Question about Toshiba 57HX81 57" Rear Projection Television
My Toshiba 57HX81 works ok for a few minutes before going out with the flashing red power LED. The diagnostic menu shows "Power :002" for the operation number of the protection circuit. All related tech manuals I've seen indicate that should be 000. Does anyone know what this is pointing to? I'd love to reduce my diagnostic efforts here! Thanks.
  • 5 more comments
  • mfoegelle Sep 29, 2010
    Thanks, I'd already seen that's a common problem and checked the fuses. None test as blown. The fact that the TV does power on and work properly and then shuts down after a period of time would seem to point to something a little less straightforward. It may well be the convergence chips about to go, or just as likely a cold solder joint in the area. Since the TV has a diagnostic code it's giving me, I was really hoping to find out the meaning of the code as opposed to just assuming it's due to the most common problem that's already publicly posted. Under the circumstances I'm not quite ready to just start desoldering convergence chips to do the diagnosis! At a minimum, guidance on the "easiest"/least intrusive way of pulling the power and convergence boards (I'd rather not pull the whole light box as shown in the service manual) would be appreciated.
    Thanks,
    M
    Thanks for the tip on the chassis. Much easier than I'd feared. I've double checked all fuses and no problems there. I'm assuming the resistors you're referring to are the convergence coil return limiters R7711, 16, 21, 26, 31, and 36 (1.8 ohms) all of which read about 2 ohms on my DMM. So, still no evidence of ancillary damage around these parts, but barring any other suggestions I guess it's time to heat up the soldering iron and **** some solder!
    Thanks,
    M
  • mfoegelle Sep 30, 2010
    Well, no joy. After desoldering and removing both ICs, the unit now goes straight to the flashing LED on plug-in/power up.
    Did so immediately after trying the unit. No such luck!
    No, but lifting up a large flexible PCB assembly that has intermittent contact would easily result in a permanently broken contact. I've already run continuity checks on the pads for the chips to ensure there were no bridges, etc.
    Trying to trace connectivity everywhere isn't terribly practical. To start testing under power I need to be able to leave the PCB in the upright position to allow probing the bottom of the board. There's one connector (P111 I believe but would have to double-check) for a cable heading towards the front through a ferrite core that I'd have to leave off. Not sure what problems leaving things open circuited like that might cause...
    Any recommended test points other than at the fuses? Note that I also have an oscilloscope, etc. at hand for more elaborate diagnostics.
    Thanks,
    M
  • mfoegelle Oct 01, 2010
    Unfortunately that's easier said than done as it will require disassembling the front panel. I may not get to that before I have to head out of town for a couple of weeks!
    M
    Ok, pulled everything and checked the voltages on all fuses and on the caps just past the rectifiers for the /- 32V supply for the convergence ICs. Everything checks out to within about a volt. A couple of points read a bit high, but that's most likely due to failure to stabilize in the few seconds it's on. The /- 32V supply is more like 38/-34, but that's because there's no load with the convergence chips removed. The caps are holding their charge long after the set powers off, so that's not the problem either. I checked that supply all the way to the convergence chips and it reads the same there, so again not the problem...
    In summary:
    F470: 120V
    F850: 17V
    F851: -17V
    F852->C852: 38V (no load)
    F853->C854: -34V (no load)
    F860: 120V
    F889: 33.8V
    F890: 11.4V
    F891: 8V
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
In this model it should be short protection--I suspect the convergence chips--each is protected with a pico fuse--two identical voltage sources--one is a positive and the other a negative voltage--if either blown--locate the chips and unsolder both--with fuse replaced and chips not soldered in--see if set comes on--if it does convergence will be out the window but you will know one of the chips is shorted--there are also number of protect resistors around them--usually 1.2 or 1.5 ohm--they will look perfect but if open.....
Let me know what you find.
SD TECH
Posted on Sep 28, 2010
  • 3 more comments
  • SD Tech
    SD Tech Sep 29, 2010
    Trouble shooting always involves trying to rule out what may or may not be the problem. You will not wave a magic wand and know what the problem is---if you tested the correct fuses and they are good it still could be the chips---You do not have to remove boards etc, it is quite common to undo some cables and leads and lift the entire chassis up so the bottom in facing the back of the set--10 minute task.
    Ten minutes more to remove solder from the chips and KNOW.
    The possible bad connections is real--some of these had jumpers in the area of the chips that break loose---No one can tell what the problem is without trying to confirm or eliminate certain things.
    If not the chips, it involves monitoring major voltage sources out of the power supply--which goes off or down first? Not easy, which is a good reason to eliminate the convergence chips first--if they have never been replaced they are the place to start.
    With both chips unsoldered the set will still come on and look bad---but does it stay on for say twenty minutes this way?
    I have been fixing sets for over 30 years---you must rule out the clear possible reasons first--it is just as valuable to know what is not the problem as it is to know if it is the problem.
    Undo the chips--if the problem is in the area or the supply voltages you will know if it is or is not the problem.
    If you do not do this you are using a dartboard---I do not suggest just replacing them but seeing if they are the problem.
    SD TECH
  • SD Tech
    For some reason my answer did not appear and I did not get a email.
    You cannot wave a magic wand here. Troubleshooting involves ruling things out.
    The board does not have to be removed--with some of the plugs that are bundled up loose there is plenty of room to get the entire chassis up so the bottom of the boards face the back of the set. Undo the solder on both chips, ten minute job.
    Even if the fuses are good, one of the chips may be causing this--no need to replace to find out--there are also some metal jumpers in that area of board that break loose from board.
    Rule chips out first and then you will know if they are or are not the problem.
    SD TECH
  • SD Tech
    SD Tech Sep 30, 2010
    Double check the fuses associated with the chips to see if gone bad.
    SD TECH
  • SD Tech
    Double check what you did when you undsoldered chips--no shorts---removing solder should not cause this problem--solder chips back if you have to and see if problem as before.
    Another option is to test voltages on the two fuses--one should be positive and the other negative voltage.
    SD TECH
  • SD Tech
    free the cable, you cannot leave a plug undone.
    I am going off the internet now and will return after noon tomorrow Pacific time.
    SD TECH
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
Keeps showing 'add ink' after adding inks & turning off/on again
This method was for 8500/8550, but we have a 8560mfp and it worked for us (with some slight modifications...). Skip step #1 and do this instead to get to the Diagnostic Menu
Click the "System" button. Select "Information", then "Troubleshooting" then "Service Tools", and finally "Enter Diagnostic Mode".
"OK" below means the check mark button on our printer.
"This may include: Low ink error, add ink error or 09,035. Error codes and more.
1) Press and hold the red button (info button) and the "OK" button simultaneously. This should take you into the Service Tools menu.
2) When in the Service Tools menu, scroll down to the "Enter Diagnostics" menu. Select the "OK" button. It will go through some cycling at this time for about 2 minutes. The screen may go blank a few times too.
3) It then asks for a confirmation, select "ok" again. The printer will go through a minute of rebooting. The screen may go blank a few times too. You are waiting for the diagnostic menu with the Test #00 "no test selected"
4) At this point hit the down arrow button until you reach the test #76. Select "OK"
5) It will ask for a confirmation. Select "OK" to confirm.
6) Then hit the down arrow button again and select the next test #75. Select "OK"
7) It will ask for a confirmation. Select "OK" to confirm.
8) Then hit the up arrow until you go over test 100 to test 01. "Exit diagnostics."Select "OK".
9) It will ask for a confirmation. Select "OK" to confirm.
10) At this time the printer will again reboot for several minutes
Oct 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
Tv turns off
Hi, your power board is in a weak state. this is being caused by major component failuer. replacing the power board will fix this issue.
Jul 09, 2009 | Toshiba 42H81 42" Rear Projection...
Xerox 8500
I've seen this with copiers in that a one second power failure and I need to reset it from the diagnostics menu. I have also seen this on printers as well. Here's the instructions for getting to the diags menu
Press and hold the red button (info button) and the “OK” button simultaneously. This should take you into the Service Tools menu.
2) When in the Service Tools menu, scroll down to the “Enter Diagnostics” menu. Select the “OK” button. It will go through some cycling at this time for about 2 minutes. The screen may go blank a few times too.
3) It then asks for a confirmation, select “ok” again. The printer will go through a minute of rebooting. The screen may go blank a few times too. You are waiting for the diagnostic menu with the Test #00 “no test selected”
4) 7) It will ask for a confirmation. Select “OK” to confirm.
8) Then hit the up arrow until you go over test 100 to test 01. “Exit diagnostics.”Select “OK”.
9) It will ask for a confirmation. Select “OK” to confirm.
10) At this time the printer will again reboot for several minutes & then should come up to a ready to print.
Dec 03, 2008 | Xerox Phaser 8500/DN Printer
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Automatically powers off, flashing red LED
try removing one neck board at a time and see if it stays on and longer,don;t let the board touch any metal or a short wil follow and you got problems.try the red first,
Sep 03, 2007 | Toshiba 43H70 43" Rear Projection...
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Toshiba 57HX81 57" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
