Question about Frigidaire ATF6000ES Front Load Washer
2001 model frigidaire front load washer . bought used , repaired shocks yet the belt will not stay on..had to overhang two v grooves beyond the end of bottom pulley to reach alignment. lasted one wash that way and now broken.was making a knock sound during spin cycle with new shocks and the oddly installed belt. the belt would roll off the top if put on fully below..all vgrooves on the pulley/transmission...any ideas?
  • 125 Answers
SOURCE: Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Posted on Jan 13, 2008
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
  • 351 Answers
SOURCE: Frigidaire front load washer model GLTF1670ASO
is the inner drum loose check to see if it moves if so may need bearings/inner drum.are the schocks rusty from water leaks.
Posted on Mar 02, 2008
  • 2651 Answers
SOURCE: Frigidaire Front Load Washer Making loud racket in last spin cycle
try pulling off lower acess panel. theres apump in rigth side corner . does it sound like theres something gaught in the squeeze the hose, try opening the door assy can you lift up on the inner basket. does it appear to have a bit of laterral movement???? how old is it???
Posted on Mar 13, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Hello Stephannie - Based on what you are describing, more than likely the belt is not aligned properly on the pulley or on the motor shaft. If possible, try lining the belt up with any pre existing marks or grooves from the original belt. If it proves to be ineffective, I would recommend reaching out to a qualified technician to proceed further with the repair(s) or installation of the belt.
May 08, 2013 | Frigidaire ATF6000ES Front Load Washer
We just bought a used Frigidaire front loader bought in 2004 and the washer jumps when in even the lowest spin cycle. We have bought a rug for under the washer and it has not helped. Any ideas???
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
Feb 02, 2011 | Washing Machines
Removing frigidaire front load washer shock absorbers
The pins just push out...they are hard to get too and push hard...a screw driver and a hammer are what I used...
Get them started and then a pump pliers on the other end and you can pull them the rest of the way out...
Washer Problems Washer noise when spinning
Sep 23, 2010 | Frigidaire FTF530FS Front Load Washer
Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Door lock doesn't release automatically; clothes still very wet
You need the Factory Repair Manual for your Affinity Washer. There is alot that can go wrong with these machines and you will need to run the washer through its diagnostics.
Here is a Link where you can Download the Affinity Washer Repair Manual
Jan 07, 2009 | Frigidaire ATF6000ES Front Load Washer
New belt runs too close to drum on pully
adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Dec 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Front Loading Washer - Load Banging During Spin Cycle
hello, your problem is that your shocks are bad and need to be replaced. you can access them by removing the front lower panel. make sure you unplug the washer first. you will see 2 of them on either side of the tub. i belive you can twist the upper portion and then remove the bottom screew and remove the shock. of course before you start you should have the new shocks. and make sure their is no water in the tub.
Dec 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Replacing belt on GE front loader wsxh208a1ww
Ron, be sure the wheel the belt goes around is not loose. The belt will come off if it is loose.
Jan 09, 2008 | GE WSXH208A Front Load Washer
Shocks broke, now drums spins freely
What you need to check thoroughly are the belt & the 2 shocks (dampers). The dampers should be replaced & fitted tightly, broader ends fitted below.
Oct 16, 2007 | Frigidaire GLTF530DS Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
69 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
