Question about Dryers
My maytag dryer run for 10 min. and then stop. wont turn on untill cool down
  • 205 Answers
Hello- The dryer may be shutting down because it senses low air flow or too much heat build-up. I would check the venting behind the dryer and make sure the flexible duct is not crimped or crushed, if it is remove it and replace (you can get this at most hardware stores). If that looks ok turn the dryer on and go outside to where the vent exits the house, the air flow should be strong. If you feel little air flow you may need to have a duct cleaning service out to get the lint build-up out, especially if the duct runs through the wall a long distance and makes many turns. You can also test if this is the issue by removing the flexible vent from the back of the dryer and running it; be aware you will get some lint in the room. If it is still shutting down you should have someone out to diagnose it, there may be a thermostat issue. Hope this helps, best regards.
Posted on Sep 27, 2010
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Starts and runs well. gone to the shop stop motor 10 mins now wont' start. calls hubby, now starts ok. this happens many times.
run the fault codes
this happens when an electronic component over heats and will not work until it cools down
Nov 15, 2015 | Cars & Trucks
My dryer makes a loud roaring sound then eventually stops and wont turn back on until it cools down
you lent vent may be clogged but I don't know much about driers sorry
Nov 12, 2013 | Dryers
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
My indesit tumble dryer idv65 runs for 10 mins and then trips the electric and stops
if its an old dryer its probably the motor thermostat heating up and shutting the motor down ,replace that or even the motor
Jan 14, 2013 | Dryers
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
Maytag mdg6700aww gas dryer runs but heat kicks out after 5 min
You have bad coils on your main gas valve . They tend to short (open) after getting warm which cuts off the gas to the burner . After cooling , they will work again for another 5 min until shorting again . Replace the coils (2 in a kit ).
Jul 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs foe a while 10 min. the it shuts off.
sounds as if you hav a bad motor assy, its tripping off on an overheat thermo and resetting when cools off, replace the motr assy
Nov 13, 2008 | Speed Queen AES28AWF Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
