Question about Panasonic Lands Phones
I have a panasonic kx-tg6521al digital cordless answering system but the answering system doesn't record message. Panasonic don't repond to my emails. I have voip IInet with disabled voice message. I have recorded my own greeting tested phone, changed to greeting only tested phone, then re-recorded message no luck. I have changed the ring time - no luck. I have turned screening on and off no luck. Not sure what to do next.
SOURCE: remote access, panasonic cordless phone and answering machine
I phoned in from another phone and retrieved my messages. The problem was not with the answering machine but with the phone and calling card I had been using. Don't use a hotel switch board nor calling card, too many intermediate parties for the 2 digit code to work with.
Posted on Aug 19, 2008
cnavarro
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Posted on Oct 01, 2008
cnavarro
  • 2460 Answers
SOURCE: We have a Panasonic cordless
Your "long gone" is on the Panasonic web site.
http://service.us.panasonic.com/operman/findmanual.aspx?model=KXTG2740
Carl
Posted on Jan 09, 2009
RPFinney
  • 385 Answers
SOURCE: Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Posted on Apr 24, 2009
SOURCE: Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Posted on Jul 30, 2009
To set up my panasonic KX-TG633 cordlessphone
Print the Manual and read it cover to cover. Or online and read beginning to end.
ftp://ftp.panasonic.com/telephone/om/kx-tg633_en_om.pdf
KX-TG633SK - Panasonic
shop.panasonic.com > Get Support
Rating: 2.7 - ‎3 reviews
DECT 6.0 PLUS 3-Handset Expandable Digital Cordless Phone with Answering System.
[PDF]Operating Instructions (English) - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-tg633_en_om.pdf Jul 15, 2016 - Operating Instructions. Cordless Telephone with Digital Answering Machine. Model No. KX-TG633SK. Before initial use, see "Getting Started".
panasonic kx tg633 manual Google Search
Aug 15, 2017 | Panasonic Lands Phones
How do I change message on panasonic KX-TGA652 cordless phone
To change the answering machine greeting message, make sure that the phone is in standby mode. Press Menu on the handset, then navigate to Answering Device with the Up/Down arrows. Press Select and then navigate to Greeting. Press Select again and highlight Record Message. Press Select and then confirm this by selecting Yes and pressing Select once more. Hold the handset about 20 cm (7.5") away from your mouth and speak the new greeting clearly. Press Stop when done and then press Off.
Alternatively, you can press # 3 0 2 after pressing Menu. Then highlight Yes and press Select. This is given in the manual for the phone. Panasonic has the manual here: http://panasonic.ae/en/manuals/KX-TG6541.pdf . See page 32.
Note: this greeting will only play if the answering system is on and you have the system respond before any telephone provider Voicemail system answers the call.
I hope this helps.
Apr 14, 2016 | Panasonic KX-TGA652B Cordless Phone 3 Pack
Is there 3 way calling on this model?
[PDF]Operating Instructions - Support - Panasonic
service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
PanasonicModel No. KX-TG2740S ... other cordless phone. For Best Performance. 3. For assistance, please call: 1-800-211-PANA(7262) ... •If you use the handset near anothercordless phone's base unit, noise may be heard. .... 2-Way Radio Communication .....&Each mailbox icon will flash if there is at least one new message in the.
Panasonic Product Support - KX-TG2740S
PanasonicObtain product support for Panasonic KX-TG2740S 2-Line 2.4GHz MultiTalk Expandable Cordless Phone System with Digital Answering System.
Jan 21, 2016 | Panasonic KX-TG2740 Cordless Phone
How do I leave a message for my answering machine
Ask the service provider
Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
change amount rings panasonic kx tg7643 Answering ...
Jan 12, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
We have a Panasonic KX T7436 phone in our office but the manual doesn't tell us how to change the voicemail message for when the phone isn't answered. Can you assist?
It doesn't tell you because the voice mail system is a separate part of the TD system. There are instructions provided with the Voice Mail system. In a Panasonic brand TVX you access it by dialing 165 and control it from either the serial port, a USB port, or mailboxes 998 and 999. 998 and a set of instructions give you access to message recording. If you don't have the instructions, you need to contract whoever set it up or find the MESSAGE MANAGER guide.
Rather than play GuessYa, comment back with the VM model number. It's either a smaller white or black/blue box mounted near the main phone system cabinet.
Carl
Apr 21, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
How can I get operation manual for panasonic kx-tg6521al please ? Specifically interested in 'call waiting" Thanks
The Panasonic site for Oceania says you can purchase a manual, but you can download the manual for the UK model from Panasonic here. It's probably similar enough that you can use it. Thanks for using Fixya!
Oct 17, 2010 | Panasonic KX-TG5566M Cordless Phone
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
How do i record a answering message on my panasonic answering m/c
Hello jmkraus,
To record a greeting message on the Panasonic Panasonic KXTG1855.
(2 minutes and 30 seconds max.):
1 Press [OK]
2 Press up/down [^]/[V]: 'Answer System' : [>]
3 Press up/down [^]/[V]: 'Record Greeting' : [>]
Hold the handset about 8 inches away and speak clearly into the microphone.
4 Press [OK] to stop recording.
5 Press [OFF]
Here's the Panasonic KXTG1855 manual download link:
http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1855.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Panasonic DECT 6.0 Expandable Cordless...
Forgot how to record outgoing message on KX-TGA
KX-TGA 101S is the model number of the hand-set. Can you send me the model number of the answering machine? Also do you have the manual for both hand-set and answering machine? If not I can give you the link to download both manuals for free.
Master FixYa...saailer@att.net
Dec 06, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TG2356 Answering Machine Problem
your message is set for 3 second delay and no record of messages i dont know particular system you use but you gotta go threw your book and set the settings to a 30 second message and 1 minute message from peeps
i had the same problem like this before with my uniden
Oct 30, 2008 | Panasonic KX-TG2356 Cordless Phone
Lands Phones Logo
270 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
