I have a Westinghouse w3213hd tv. The pictuer as gone, all I get are three horizontal bands of colored verticle lines. It doesn't matter what the video source is DVD, Sat, etc. Is this a boat anchor or worth repairing?
2 Suggested Answers
jdbouncer
  • 72 Answers
SOURCE: power supply
best place to look is ebay and see if anyone has one up for sale. Usually get one really cheap compared to getting a new one. But if u want a new one do a internet search for one type manufacture and power supply and part number. Or u can check parts.com
Posted on May 03, 2008
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Verticle lines on monitor
Hi there.
I have written a very helpful tip about this problem recently.
Check it out here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Jan 17, 2012 | Westinghouse LCM-19v1 Monitor
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Look like the image is divide on three.red,blue,green .yesterday was normal.my son finish video game and turn off.Today I turn on and the image cannot show all colors together.
this is a normal problum pls. check remot cantrol on menu key press then selact convergen seting see on the screen canter three cross line arrow to set UP / DW/ LIFT/ RIGHT key maeching 3 line and see cross line is White then see the pictuer is ok
if not working convergen seting then spare STK replace in inside your tv set
Oct 29, 2009 | Sony KP-61HS30 TV
Screen looks like color bar code
the answer will deprnd on how the fault occured
the tv may have had a knock (kids in house!!) in which case it could the the lcd panel gone
if a normal fault the more than likely the ldvs cable or dry joints either way not a job for the untrained
May 27, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Verticlel lines appear when colorprinting photos
There may be multiple reasons why your pictures and printed pages have unexpected vertical or horizontal lines. To resolve this problem,
http://www.kodak.com/global/en/service/repair/troubleshooting/aio-troubleshooting.jhtml?pq-path=10355
Within the Link, select Print quality, then Unexpected vertical or horizontal lines (banding).
Nov 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Horizontal line on Philips TV
this indicates that your verticle is gone and it has only three major problems
a verticle ic might go faulty or a capacitor drying up
or awire on the scanner coil is out, for verticle
okay
Sep 03, 2008 | Philips 27PT6441 27" TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
