Question about HP zv5160US Notebook
Goy slower and slower and then locked up, is better when first started cold,
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 27, 2010
How to bypass prndl sensor
Which part of ignition switch did you replace ? The key an lock cylinder or the electrical part behind the lock cylinder ? What year ,make an model vehicle do you have ? Most all newer vehicles from 1996 on have anti-theft systems . Is there a security light lit on your dash ? These same vehicles have a starter relay in the under hood fuse box that is turned on or energized by the PCM/ECM - engine computer . The switch the mechanic told you about is the transmission range selector or park neutral safety switch. Your best bet , rather then replacing parts is to take it to a ASE certified repair facility .
Nov 21, 2015 | Cars & Trucks
Wont start with fuel and spark
did you try putting a little fuel in the carb to see if it starts. if it does you goy carb or fuel line problems. if it does not remove spark plug and look at inside of cylinder for scoring if there is saw is junk.
Oct 11, 2014 | Garden
My 1994 samurai idles really high when I first crank it, but later slow down. is there anyting I can do to ?
From a cold start my sami idles really fast, but as I drive it and the engine warms up it will idle correctly. Is there a way to make it idle slower from a cold start?
what engine ? 1.3 L
carb or EFI? (94 was first year of efi, and many have been converted this old)
but the answer is the same , that is normal.
on car its a fast ilde cam on the carb.
in EFI its on the software and in the IAC thermal valve.
Mar 29, 2013 | 1994 Suzuki Samurai
When the transmission is cold, when put in reverse, there is some hesitation and it goes in hard.
Hello, You may just need to have fresh fluid and have the internal filter cleaned or replaced. There can also be a problem with the Cold start sequence for the engine. The Cold start sequence keeps the engine idle higher for a short time like the old choke system.
If your idle is slower when cold, it will take longer for the fluid to move to where it needs to be. The hesitation and hard shift can be the fluid trying to flow when it is thick. Yet the hesitation is also the thing carbureted engines would do when the choke was not working.
The other thing you can do is have the Electronics analyzed to see if the shift solenoids in the transmission are working properly, but this will take a Dealer or better transmission shop to have the tools and do the testing. Your cheapest route is fresh fluid and a clean filter and go from there.
I hope my solution is very helpful to you.
Apr 17, 2011 | 2005 Mercury Montego
What type of tires would you recommend for winter driving?
latitude-x-ice.jpg Latitude® X-Ice®
Winter
Winter Tires
Better Starting Grip in Icy Conditions.
A special Winter Flex Compound, specially formulated to maintain its grip under the most extreme cold-weather conditions, including snow and ice, to help deliver better starting grip and shorter stopping distances.
Better Traction In All Winter Conditions
Cross Z-Sipes Technology uses a specially designed curve that locks the sipes in place, helping to provide improved grip on snow and ice. And because the sipes are full-depth, their grip lasts winter after winter.
Quiet, Smooth Ride in Cold-Weather Conditions
Dec 02, 2010 | 1996 Jeep Grand Cherokee
Cold water fill is very slow and makes strange sound
check with the plumbing work if that is fine then better take it to the dealer to change the inlet valve. attempting to change by yourself can cause other complications.
Oct 04, 2009 | KitchenAid KHWS01PWH Global Horizontal...
1999 nissan quest will start when cold then try to take off then die wont start
Check your crank sensor. You might have an oil leak that is getting inside the sensor which is the reason why it wont start when hot. When oil is cold, its thicker so it leaks slower. Have a mech check it out.
Sep 09, 2009 | Nissan Quest Cars & Trucks
Water flow slow on rinse cycle
the rinse cycle is almost always slower because it is only using cold water - if you try cold wash, cold rinse, they should be the same flow- cold is used for rinse because it reduces suds better
Aug 25, 2009 | Roper Washing Machines
My bobbin winder starts and then freezes and an alarm sounds-
Try to sew slower. In my sewing class the bobbin always freezes, and if I go slower it works better sometimes.
Jan 24, 2009 | Singer 7442 Mechanical Sewing Machine
HP zv5160US Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
