Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System
Everythin in the fridge is freezing and the water dispersing on the door has stopped comming out
My fridge isn't working properly temp control stopped working everythings freezing even the water dispenser stopped working
  • lillylou Jan 10, 2009
    American Fridge Freezer side by side, everything in fridge is freezing even the eggs!
I have the same problem,
Have you found a solution yet?
Posted on Sep 26, 2008
    President:
  • 1,314 Answers
Replace the temp control
Posted on May 23, 2008
Water Dispenser Temperature Control/switch-off
Not on regular models. Most models have a water tank in the fridge compartment which makes the water temperature to stay just above freezing temperature.
Wanna a play with your unit. Then remove the tank and just add two pipe ends together. Eliminating the tank. Then you should get room temperature water after about 5 seconds of cold water. Be careful just connecting the two ends of pipe after removing tank might lead to freezing pipes if your fridge temperature is close to freezing temp.
Nov 26, 2013 | Samsung RF4287HA
My amerian fridge freeze the fridge is frezzing everything
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem as you read the above information to get your fridge freezer back again...
Jun 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker overfills and freezes solid so wont dispense. also freezer has frost on everything
I hope this help out....
May 07, 2011 | GE Americana A4425GDTWW Side by Side...
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Whirlpool S20BRSB21: The fridge side keeps freezing
call a repair service , the air damper control needs fixed, if you have lowered the control value all you can
Mar 04, 2018 | Whirlpool Refrigerators
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System Logo
230 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
