Question about Nikon COOLPIX L20 Digital Camera
It was dropped and now the lens will not retract. When turned on it only says lens error and then turns off. Oh, it trys to clos or open but nothing. I've taken the body off but not sure what the next step if any should be. Any solving direction would be fantabulous. An I thank in advance. Katies dad
  • 5,081 Answers
The lens alignment have been lost when you dropped it down . So only it is throwing the LENS ERROR.
Try adjusting the lens to its original position..Do not apply too must pressure to break it...We have to open the lens area and readjust it which can be done by authorized technicians only..
Posted on Sep 27, 2010
My Camera lens trys to open but wont.
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Jun 03, 2011 | Vivitar ViviCam 5386 Digital Camera
Lens Error - won't retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2010 | Canon PowerShot A540 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
My sony camera displays Turn camera off and on again
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 09, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Lens error, restart camera
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
KODAK Z1275
I semi resolved the problem with my Kodak Z1275 with this suggestion; Step 1, making SURE the batteries are good. Then, position the camera with the lens pointed up or down (depending on stuck lens position, USE GRAVITY AS YOUR FRIEND) and gently tap on the lens just as you turn on/off the camera. You may have to do this several times before the camera will close the lens. From my research this camera has a faulty mechanism for the lens which causes the software to recognize a lens failure thus shutting down the camera. Poor designed lens mechanism! I now am using my camera again, but regularly have to remember to allow gravity to assist in lens opening (turning on) and lens closing (turning off) as well as occasionally giving it a light tap or in extreme cases lightly assisting the lens opening/closing. Hope that helps! Oh and I don't suggest buying another Kodak camera!
Sep 15, 2008 | Kodak EasyShare Z1275 Digital Camera
Lens won't retract
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 21, 2008 | Canon PowerShot A430 Digital Camera
The lens on my camera won't retract.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
