Question about Microwave Ovens
C970-445622 Self cleaning electric range HELP! I did not get a manual when we purchased our home. I have run the self cleaning mode twice this year but only by sheer luck...I press buttons in every possible sequence until it works. But still haven't figured out the exact procedure...thanks for your help!
MicrowaveSvc
  • 9085 Answers
SOURCE: r-9h81 sharp microwave oven
I'm sorry, but the keypads for for Sharp R-9H-type models are no longer available.
Please don't kill the messenger, but unfortunately, once the oven becomes unusable it will have to be retired.
Posted on Sep 06, 2008
kel1guy2002
  • 3740 Answers
SOURCE: my GE microwave started running by it's self. It
It sounds as if you key pad is sticking. PF means that there is an input power problem but could be caused by the sticking keypad.. As far as the unit starting bu itself, the only thing that can cause that is the keypad.. Try running your fingers flat across the panel several times both vertically and horizontally and see if the pad malfunction clears. It will probably repeat in the future but you could get lucky and have a one time instance. The keypad itself is just a bit over $75.00 if it has failed. Good luck.
Posted on Jan 12, 2010
  • 1340 Answers
SOURCE: I have a Thermador ME272
I would almost guarantee the thermocouple is bad.It is a small rod whose wires come out from the back wall into the oven and is mounted inside the oven,usually near the top.This is a common fail component in ovens due to the temperatures it endures over time,especially with self-cleaning because they usually go over the maximum temperature cooking allowed during cleaning.If you want to test it yourself,you or someone can swap out the 2 thermocouples as they should be identical..Make sure the circuit braker is pulled first.Behind the oven there is probably a cover which is fairly easy to access.If it is possible to switch the 2 connectors without removing the thermocouples,it would obviously be much quicker.If you switch them and turn both ovens on,the problem should switch ovens also.If you switch the thermocouples and the problem DOES NOT switch ovens,the bottom doesn't work but top still does,the circuit board is bad.Wait about a half hour before touching the thermocouple after heatup and leave the door open.Good luck,Greg
Posted on Nov 21, 2010
dcramer531
  • 1654 Answers
SOURCE: WHEN TRYING TO SELF CLEAN
The E1 - F5 error code indicates that the oven door lock assembly is not operating. The oven will not begin the self clean cycle unless the oven door is properly locked. This failure is normally caused by a failed door lock assembly. In rare instances, it can be caused by a failed control board or a wiring failure. The normal troubleshooting for this problem is to unplug the range and check the wire harness connections between the control board and the door lock assembly. The first image below shows the access information for the components in this model of range. The second image shows the wiring diagram with the door lock circuit highlighted. If you are able to unplug the range and check the wiring connections, you can likely fix this problem yourself. If the wiring connections are okay, the next step in troubleshooting is to replace the door lock assembly (part W10107820). You can order this part from the Sears PartsDirect website. Replacing this part will likely fix your problem. If you replace the door lock assembly and still have the same problem then the electronic oven control board may also need to be replaced. If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Posted on Nov 23, 2010
alpug
  • 1961 Answers
SOURCE: I have a Beaumark Self-Cleaning
The closest manual I could give is the Maytag Beaumark Self-Cleaning Oven Manual
Its a pdf file so you need Adobe Acrobat Reader installed in your system to view this file
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0811498.pdf
self-cleaning operation can be found on page 15.
Posted on Jan 30, 2011
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
All i know about my self cleaning oven is that it is a frigidaire. it was here when i moved in. i want to use the self cleaner but i have no idea how. nothing on it is digital. its all knobs. i have no...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 09, 2011 | Frigidaire Microwave Ovens
I have a Caloric stove of the prestige series with a self cleaning oven. How do you turn on the self cleaning oven?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 22, 2011 | Microwave Ovens
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
Lost my oven control guide. how do I set the self clean function on the kenmore elite dual fuel range
heatman101
Jan 04, 2011 | Microwave Ovens
How to self clean
heatman101
Jan 03, 2011 | Microwave Ovens
I do not have a manual to tell me how to use my self cleaning oven.
heatman101
Dec 24, 2010 | Microwave Ovens
WHEN TRYING TO SELF CLEAN OUR KENMORE ELECTRIC RANGE WE GET THE E1-F5 LIGHT?
Nov 23, 2010 | Microwave Ovens
I have a GE profile double wall oven. I do not have to owners manual. I know I just press clean to clean the ovens, but how long do I set the timer for?
heatman101
Sep 25, 2010 | GE Microwave Ovens
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
