Question about Acer Aspire 4315 Notebook
Faulty key - Acer Aspire 4315 Notebook
  • 2,567 Answers
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Posted on Sep 27, 2010
What is code B2799
This Diagnostic Trouble Code (DTC) is output when the Engine Control Module (ECM) detects errors in communication between the Transponder Key Electronic Control Unit (ECU) assembly and the ECM, or in the communication lines. This DTC is also output when an engine start is attempted while the ECU communication ID between the transponder key ECU assembly and the ECM is different.
Possible causes Faulty Key Faulty transponder key amplifier Faulty Transponder Key Electronic Control Unit (ECU) Transponder key amplifier wire harness Faulty Engine Control Module (ECM)
Mar 02, 2013 | 2007 Lexus ES 350
2008 dodge caravan with KeyError message and it wont start ............tried charging battery, changed battery and key and nothing
This sounds like the key fob is faulty, you will have to take the vehicle to the dealer and have them verify the key fob is faulty, then you can get another key fob programmed for your vehicle, hope this helps
Oct 17, 2012 | 2008 Dodge Grand Caravan
Compaq cq60 keys not working
The keyboard maybe faulty.
Connect an external keyboard to youe laptop and if all the key work on this keyboard then most like the laptop keyboard is faulty.
If this external keyboard also malfunctions then the keyboard controller chip on the laptop motherboard is faulty and it would not be worth repairing as this is an old model laptop.
Mar 04, 2012 | Compaq Presario CQ60-212US Notebook
Compaq CQ60 some keys not working
Do i have a faulty "A" key or a faulty keyboard?
You will need to purchase a keyboard replacement. Thanks for using FixYa! You can purchase them rather cheap at Amazon.com
Feb 06, 2012 | Dell Inspiron Computers & Internet
@ key is not working when i press the shift key and @ its only giving me #2
Then your shift key may be faulty, try using the shift key on both sides of the keyboard to do this. If it still doesn't work then it means that your shift keys are fine its just the secondary functing of the "2" key that is faulty.
Mar 15, 2011 | HP DC170B Keyboard
Can my key be reprogrammed in the ignition
The electronic key which you have only need to programme once, then it will work till get faulty not necessary to re programme there are only one way to re programme, it's only can do with new electronic ignition switch replacement so if you replace new ignition switch insert your key in it and it will take few minute for programme it take all the programme automatically then you can turn the key and start the car,
If you don't have replace the ignition switch but key is not working it's faulty either key or electronic ignition switch, if you have any other additional key if the car start with that key it's very clear it's faulty your key which is not working give me more details do you have the other key and only not working one key like that, however first replace the battery for your key and try if not work put a comment i will give you more details,
Nov 12, 2010 | 1999 Mercedes-Benz E-Class
Mac laptop keys are not showing letters but symbols and delete key not working. How do I unlock this problem?
There could be a couple of possibilities :-
1. Faulty keypad
2. IC on the main board
Faulty keyboard is more often a problem. Even though there is no dust and dirt, faulty keyboard may result in all the above said symptoms.If you press a letter key, a symbol might be there. If you press delete key, it might not work. The best option what i follow in my shop is replacement of keyboard. There are certain days when i only replace few keys, but more often if this is a problem with more than 5 keys or with all the keys on the notebook, better to go for a new keyboard.For your laptop, always prefer hard keys as those are more durable than the soft keys.
IC on the notebook is again one of the reasons. This is usually a problem with old laptops, such as 5 to 7 years old. New laptops generally do not have this problem. If laptop IC is at fault, soldering is required to get it fixed.It needs a tech to confirm the faulty IC on the mainboard and then followed by replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 03, 2010 | Computers & Internet
The 3 keys (space,6,4) dosn`t work by A300 toshiba satellite keyboard
try a screen recalibration and then see if that fixes it
Jul 26, 2009 | Computers & Internet
Acer Aspire 4315 Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
