Question about Coleman Heating & Cooling
Have a coleman furnace and its kicks on but blows out cold air and then flashes 3 green lights and says combustion air switch failed to close. can u help
  • 407 Answers
There will be a small tube that goes from the induction blower housing to the switch itself. Try to blow and **** through this tube with it attached to the switch. If you hear a click on the inside of the switch, it is good, if not, then it needs to be replaced. Another thing to try, take a small wire or paperclip and poke through the hole that the hose came off of on the housing, sometimes this gets clogged and will cause the same problem. Other than that, it will be a blocked flue or the inductive blower itself not performing properly. Hope this helps and good luck!
Posted on Sep 28, 2010
Combustion Air Switch Failed to Close
I have this furnace in two of my mobile homes. In both I had to take off the inducer motor (i think that's what it's called)..it has the clear air tube attached to it. Remove the 4 screws or top two if you have small fingers and give the wheel inside at the bottom a push. These tend to stick over years of use and in both cases once freed the furnace came on. I too had 3 flashes in both cases.
May 09, 2012 | Coleman Propane Forced Air Heater...
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Sep 21, 2011 | Coleman Heating & Cooling
Furnace won't come on Green lights flashes 3 timesSays Combustion air switch failed to close.
Hello, the switch can fail to close for several reasons. A blocked or restricted flue pipe, water or restriction in small tubing going from pressure switch to inducer motor, weak inducer motor, or the switch itself is bad. Take off the small hose and try blowing through it, sometimes it could just be a small restriction in it.
Sep 16, 2011 | Heating & Cooling
Trying to light the coleman furnace and error flashes says "Combustion air switch failed to close. Have turned circut breaker off and tried to start it several times. Cannot even get it to light.
Make sure both the exhaust vent and the air intake vent is clear of any obstruction. If the pipes do not pitch back toward furnace, they may have water in them blocking the flow of air. Also check the condensate drain and pump for blockage.
Oct 03, 2010 | Coleman Heating & Cooling
Coleman furnace has green light blinking 3 times. lost manual. What does the code mean?
light blinking 3 times means that your combustion air switch failed to close.
Oct 02, 2010 | Heating & Cooling
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Heater flashes 3 times says it means combustion switch failed to close
Combustion switch is your vent safety.. Check your vents outside for blockage, sometimes the intake pipe will freeze or frost up not allowing the preassure switch(vent safety)to close. putting furnace into a lock out.. you can reset the furnace by turning the power on and off.. if there is no power switch just remove the bottom door and reinstall...
Jan 08, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
277 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
