Question about Voyetra Turtle Beach Ear Force X3 Wireless Headphones for Xbox 360
I accidentally stepped on the cord that goes Into the headset and it pulled on the cord and It just stopped working, please help me.
  • Voyetra Turt... Master
  • 17,129 Answers
All that needs to be done is to check the continuity of the cord and fix it back to the section of the jack or the headset.
Most possible the wire would have stretched and so you will need a stereo cable that needs to be soldered into the jack and headset ,only if continuity is lost in the stretched wire .
Posted on Sep 27, 2010
Why am i getting no power in x42 turtle beach earphone?
I am assuming this is not a sound issue, and an entire headset not coming on issue. Here are the steps that I would take...
1. Put in BRAND NEW BATTERIES!!! (Usually that is the culprit) ;-)
2. Unplug and then re-plug in all wires and cords to the console and the controller.
3. Check to see if the wires are connected from headset to end cords (on the one that plugs into the controller).
4. Once everything is connected and with brand new batteries, it should work, turn it on again. Remember the beep sound goes up when the turtle beaches come on, and the beep sound goes down when the turtle beaches are turned off.
Jul 02, 2014 | Turtle Beach Ear Force X42 Headset
Why won't my motorola finiti connect to my PS3?
I'm having this problem and need help please for my 12 yeatr old son
Jun 10, 2012 | Motorola Mobility FINITI Headset
The sound goes on and off. i have to tilt my head to the right to hear a sound. or i have to pull the cord.
sounds like you have a loose wire inside. suggest you get it repaired. unless you have the patience and skilll to repair it yourself. the wires are really thin in headsets.
Jul 12, 2011 | Logitech ClearChat Stereo Headset Headset
I got this headset a long time ago and its been working great.... the only problem is that the cord from the computer to the headset is a giant mess it is twisting together in aton of little knots.... I...
You can try window cleaner lightly sprayed on to a cleaning rag. While gently pulling the rag down the cord you straighten as you go. Try to lay flat to help the crinkling.
Good luck from Headsets Direct!
Feb 22, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
Won't turn on
try to replace the ac cord it maybe damaged when it was accidentally pulled out
May 05, 2010 | Sirius Boombox for Select Satellite Radio...
Headsets do not work
semes to be coppe wire inside it cut so if it move it work then move stop so chik with voltmeter if find where is the cut u can soldring it agin if not have new one
Aug 18, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
Bluetooth headset now will not pair up with my LG enV
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 20, 2009 | OEM Systems Motorola Bluetooth Headset...
Broken pull cord
ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Headset wont turn on
You change the battery's? Did you step on the headset ?
Nov 27, 2008 | Microsoft Limited Edition Halo 3 Wireless...
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
Voyetra Turtle Beach Ear Force X3 Wireless Headphones for Xbox 360 Logo
257 people viewed this question
Top Voyetra Turtle Beach Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Voyetra Turtle Beach Audio Player and Recorder Expert? Answer questions, earn points and help others
