Question about RCA 20F420T 20" TV
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Posted on Oct 03, 2010
Hi how to open fpa
The front panel lock can only be unlocked with the remote. Press Menu, then Ch+ or Ch - to select Preferences. Press Ok then use the Ch+ or Ch- buttons to highlight FPA (front panel) lock. Then use the Vol+ and Vol - buttons to select On or Off. Then press Menu repeatedly to exit the menu system. With the FPA lock disabled, you can turn it on from the front panel of the TV by pressing the Menu button. However, with the lock enabled, you can only power off the TV from the front panel.
Since the Input button is also only on the remote, if you look for a universal remote, choose one with both Menu and Input or Source functions. Then try all the RCA codes until you find one that makes all of the remote functions work. The original remote is: RCR130TA1 . A substitute remote that should match all of the functions is available here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=13004957447460 .
The manual for the RCA 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . If the direct link doesn't work, start here: http://support.ttetech.com/en-us/productdownloads.html . Select a 20" TV and then your model number in the drop down menus and press Go.
I hope this helps.
Mar 19, 2011 | RCA 20F420T 20" TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
FPA LOCK IS ON AND I HAVE NO REMOTE FOR THE TELEVISION,,, HOW CAN I FIX THIS?
You will need an RCA Remote or Universal (RCA) may work. Once the Front Panel Assy. is locked the TV will only Power on with a remote. Call an Authorized RCA warranty service center, and offer to leave a deposit for the use of the remote. Power the TV on with the remote. Press Menu on remote. Press CH- (down) button on remote to highlight "Preferences". Press OK button to open menu. Press CH-(down) button to highlight "FPA Lock". Press Vol.+ button to turn off FPA Lock.Press Menu button to return to Main Menu. Press Menu button again to clear On Screen Display.
Dec 23, 2008 | RCA 20F420T 20" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
FPA Lock
just get a universal remote... it will work just fine.
Jun 10, 2008 | RCA 20F420T 20" TV
FPA lock
hi i have a universal remote and my granddaughter pressed a button on the tv and now i need to unlock the fpa can some one please help.
Mar 08, 2008 | RCA 20F420T 20" TV
RCA 20F420T FPA lock
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jan 21, 2008 | RCA 20F420T 20" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
FDA Lock
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Aug 21, 2007 | RCA 20F420T 20" TV
RCA 20F420T 20" TV Logo
281 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
