Question about Night Owl Optics Explorer NOCX3 Monocular
Put in a new battery but the power won't come on. I checked and the + is right.
  • 17,129 Answers
It can be related to a failure on the inside of the unit if your battery is good and the contacts are fine.
So thebest is to have the tools necessary to open out and check if there is any minor fault of a line break or a possible fusible resistor that opened out.
If you find power to the circuits in order then the fault is in the board and can be the control IC.
Posted on Sep 27, 2010
We just put a brand new battery and terminals still won't start. What could be the problem with my 1991 ford tempo
Have your alternator tested. Check spark plugs and distributor/dist. Cap. Also if you post your problem under car and truck problems people would be able to see it. Right now it is posted under SLR cameras
Apr 02, 2013 | Photography
1999 durango won't start
starter?
New battery drained = something is still powered, open/short.
new ign switch and steering won't lock = something was not put together right and the ignition is staying on and draining the battery.
Jan 19, 2013 | 1999 Dodge Durango
Car won't start
Is the battery good in it?
Dec 04, 2012 | 1997 Lincoln Continental
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
My car won't start and we just put a brand new battery on it but it's still not getting any power. What could it be?
if the starter is not receiving any power at all you might want to check the fuse able link,this is located on your positive battery wire,also check the rest of your fuses
Nov 01, 2011 | 2006 Dodge Stratus
My student's ti nspire won't turn on. They have the 84 face plate on it.
Put in new batteries and try again.
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 12, 2011 | Texas Instruments TI-Nspire Graphic...
V-star 650 won't start and the headlight won't come on. Battery was replaced, new gas put in. now what?
Replace your right switch assembly on the handle bar. Your starter button is dirty or broken and the only way to replace it is to replace the assembly. Your starter button is a two position switch that both turns off the headlight to direct more power to the starter and activates your starter solenoid. Either the right switch assembly has become unplugged from the harness inside the head light bucket or a broken power wire is causing the system to not work. But most likely a dirty or broken starter button is the cause of your problems.
Jul 07, 2011 | Yamaha V Star Classic Motorcycles
I remplace a new alternator and battery on a BMW x5 2001 it won'
theres an anti-theft system. take positive terminal off battery, have someone holding the key on like trying to start it, then put the terminal back on and that should start it right up (had same problem in my dodge ram) if not, check all you're connections
Aug 16, 2009 | 2001 BMW 5 Series
Night Owl Optics Explorer NOCX3 Monocular Logo
193 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
Ted Maxwell
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
