Question about Canon FAX-L100 Plain Paper Laser Fax
Caution check Scan platform error. Cant find information in book
4 Suggested Answers
SOURCE: caution check scan platform
SCAN PLATFORM LOCATED UNDERNEATH NAER PAPER TRAY HAS DROPPED DOWN NEEDS CLIPPING BACK INTO POSITION.
Posted on Jan 21, 2008
canontech
  • 1219 Answers
SOURCE: check scan platform
Above paper cover, there is scann platform. Put it back in up possition.
Posted on Jun 25, 2010
SOURCE: coulnd't send a fax
Good solution..
Thanks a lot
Posted on Jul 10, 2008
Samsung chromebook recovery. i get keep getting error messages when loading recovery image and the chromebook says its a trusted platform error. i dont know why this is happening
Trusted Platform Manager.
This issue occurs because the TPM is using the OEM driver and not the Windows built-in Trusted Platform Module driver.
To resolve this issue, open Device Manager on the device on which you are experiencing the issue, and then uninstall the Trusted Platform Module driver.
If you do a hardware scan, the TPM will be detected as a security device and will use the Microsoft driver. Additionally, the TPM will now be listed under Security Devices as "Trusted Platform Module 1.2."
Aug 14, 2016 | Samsung Computers & Internet
Canon L120 - What does this error message mean?
Check Scan Platform, means:
The scanning platform is dirty, or not set into scanning position.
Solution
Clean the scanning area, or lift the scanning platform into place.
Nov 26, 2011 | Canon L120 Fax Laser Printer
Fax machine
Scan platform is located above paper cover. Its like long rectangle with wite stripe and scaner. In some cases it falls down and the documents from feeder cant came trough.
Push it up back, and should work.
If doesnt works, you have bad main pcb fault.
Jul 14, 2010 | Canon FAX L-120 Plain Paper Laser
Cant fax, getting a msg "check scan.platform" Thank you, Z
When you remove plastic cover, wich is above paper cass. you will be able to see long black plastic with white scanner section.In the midlle is handle.
You need to open and very vell close it - THIS IS SCANING PLATFORM.
If does not help you have problem with main pcb.
Jun 15, 2010 | Canon L120 Fax Laser Printer
Check scan platform
Jun 11, 2010 | Canon FAX L-120 Plain Paper Laser
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Cant download videos from kodac to the cp
Can we get more information? What happens when you try to import them?
Does it give an error?
What platform is this on? XP? Vista?
Jan 29, 2009 | Kodak EasyShare C875 Digital Camera
Canon Fax-L120/L100
Check the manual for how to clean the scan platform (glass).
Jul 02, 2008 | Canon L120 Fax Laser Printer
Coulnd't send a fax
I had the same problem and called canon helpline.
They said to unplug the machine from the mains, then take out the plastic guard where the paper tray is fitted. There is a lever just above the paper tray. Make sure that it is pressed up completely. Then reconnect to mains.
I tried it and it worked.
Dec 27, 2007 | Canon FAX-L1000 Plain Paper Laser
Caution check scan platform
you need to check the scanning platform that is above the paper tray. it may be loose. you will have to close it properly and hopefully it will start working.
regards,
kumar
Oct 15, 2007 | Canon FAX L-120 Plain Paper Laser
Canon FAX-L100 Plain Paper Laser Fax Logo
266 people viewed this question
old marine
old marine
