Question about Casio Exilim EX-S880 Digital Camera
Powers up- 2 beeps, lens telescopes out, then 2 beeps -lens retracts and powers off.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Camera will not come on but green light flashes and camera makes three beeping sounds. Already changed batteries and still same thing when powered on. What could be causing this problem?
The reason why your Samsung Digimax S500 camera beeps 3 times and shuts down is because the internal workings of the telescoping / retracting lens barrels may be damaged beyond reasonable repair, of the casual user, and the internal circuitry senses the malfunction.
And to open up and attempt to service any digital camera, with an electronic flash, is a dangerous proposition. The Samsung Digimax S500, for example, has an internal 320 Volt, 110 microfarad photo-flash capacitor that, if accidentally touched, would hit you like a stun gun. In fact, I had to discharge the capacitor by bridging two soldered contacts (just to the upper-left and upper-right of the "53", of the "STS2-53-SR" printed on the internal circuit board). And, even though I was careful to use an old, worn out flat-head screwdriver, electrically grounded (MUST have an insulated wooden or plastic handle), the discharge arc was so violent that it destroyed the tip of the screwdriver.
And don't think that the telescoping / retracting lens barrel can be "gently forced" open or closed, as the tiny DC motor has a plastic worm-gear on its shaft, initiating torque to a miniature train of 7 plastic spur gears, before reaching the final plastic spur gear track, 120 degrees part-way around the large outside lens barrel. So, to make a long story short, any attempt to manually move the lens barrel out, or in, will most certainly damage the spur gears, as absolutely no manual movement is possible at the worm gear on the motor shaft. And, anyway, the geared motor drive provides more than enough torque, by itself, to extend / retract the lens barrel, unless there is grit and debris interfering with the smooth motion of the gears and angled slots.
Sand, grit, and other debris can sometimes find its way between both lens barrels, and into the curved, 120 degree spur gear track. And since the 120 degree spur gear track is not lubricated, it can possibly be cleaned by very lightly tapping the camera on a table top, with the lens down (this is assuming that both lens barrels are fully retracted) , to loosen any debris, and then using a vacuum cleaner: Taking care to apply the open nozzle of the vacuum cleaner, tilted (to reduce its intensity), but directly on the perimeter of both lens barrels, so as not to **** the lens barrels out, yet apply a strong vacuum into the narrow grooves.
This may damage your camera -but do you really have a choice?
Also, a piece of paper can easily inserted between the lens barrels and run along the circumference to help clean out some of the grit. And repeat the process above, until the lens works.
But that's assuming that the problem is caused by dirt and grit in the inner workings of the lens.
The other cause for the telescoping / retracting lens barrel to malfunction is either the camera was dropped (while the lens barrels were extended), or the camera "POWER" button was somehow depressed while the camera was stowed away, and the lens barrel was prevented from extending. Either situations will break off 2 teeth of the final circular plastic spur gear, that powers the 120 degree spur gear track on the outer lens barrel. If you know either of these to be the case, then your camera cannot be fixed, and a repair would probably cost more than the camera.
Dec 04, 2011 | Samsung Digimax S500 Digital Camera
Should I be using the 2x lens or the 1.5x lens for looking at stars, also what is the correct setup of the different lens?
No matter how much magnification you use stars are always just points of light. You cannot resolve a star into a disk.
Your scope will work better at lower powers. I probably would NEVER use either the 2x lens. The maximum magnification of any telescope is about 50 times aperture. You scope is about 2-3 inches so your max is about 120 power under PERFECT sky conditions.
Read the TIPS on my profile page.
Feb 07, 2010 | Bushnell Voyager 78-9945 Telescope
Camera was on, working fine. When powering off, telescoping lens did not retract so lens remained extended just a bit with lens cover open. Waited a few minutes, turned it back on and I get the "access"...
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 20, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
What does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Jul 10, 2009 | Canon PowerShot S50 Digital Camera
Flashing yellow light -- lens won't retract
Lens is jammed, you need to get it back on track. Gently push lens back in with a flat object to keep it straight, like a tabletop while powering it on. This may or may not work, but a jammed lens on these styles of cameras is common and renders the camera useless.
Dec 07, 2008 | Canon PowerShot A80 Digital Camera
Beeping, bad noises, then turns itself off
If you have a retractable lens then that could be causing the problem. The beeps is letting you know that it's wrong and it shut off as a safe guard. So the noise you are hearing is the motor and gears for the lens.
Jan 27, 2008 | Samsung Digimax S700 Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
184 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
