Back to:
Tags:
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Igniters will not turn off
posted by michaelsigma on May 23, 2008
I have a jenn -air CVGX2423. The igniters work great, however when they light the range, they do not turn back off, they just keep clicking and clicking. When the gas on the range is turned off again, the clicking stops. Any suggestions?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 15, 2008
Not Rated (0)
Bob from LI
Rank:Guru Guru
Rating: 85%, 438 votes
Your switch assembly on the valve shaft has come loose or has broken. Have a look.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Igniters will not turn off:
I don't want to Accept this solution
Can you Help with these Kitchen Cooktops problems?
Jenn-Air 34 in. Expressions CVGX2423 Gas...
All other igniter keep making spark and noice when any...
We have an Jenn-Air gas range, it has the problem that...
Fan will not turn off. Need a new fan switch. Where do I...
There is a small gap where the filter meets metal
I have a Jenn-Air Expressions cvgx2423b model with the...
Loading problems.
Repair Service
Find Kitchen Cooktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
