Question about HP Pavilion dv2120us Notebook
I put my HP Pavilion into hibernation and now I can't get it to start up again! When I press the power button, the little lightening bolt flashes but that's about it. Any suggestions to get this thing turned on???
  • starcatch589 Sep 27, 2010
    This was most helpful - thank you.
  • HP Master
  • 629 Answers
Try to press and hold the power button for about 5 to 10 secs. if this does not work, remove the battery and adapter, press and hold the power button for about 10 seconds, reconnect the battery and adapter and attempt to turn on the laptop. let me know how it goes.
Posted on Sep 27, 2010
  • Rodie Sep 27, 2010
    glad to have helped. :-)
Can HP dv2715nr hibernate instead of putting it on sleep mode?
It sounds like the hibernate feature is missing from the power options list. Click on start button, select shut down, and then hold shif or ctrl and stand by should change to hibernate.
Let me know how you get on.
Regards.
Mar 11, 2010 | HP Pavilion dv2715nr Notebook
Hi I have a HP pavilion a708uk pc when i power up the cpu fan run full speed the the screen says "hibernating" then shuts down! any ideas?
You can try the following steps to resolve this issue:
Turn off the computer
Remove the power cable
Press the power button and hold it for atleast 8 seconds
Reconnect the power cable
Try to restart the computer and see if you are able to get on to the Desktop.
If the above steps does not work and you again get the "hibernate" screen, immediately press the "Esc"(escape) key on your keyboard. It should let you go to Desktop.
Once you are able to boot normally do the following:
Right click on Desktop
Click properties
Go to Screensaver Tab
Click on Power button
On the Power Options Properties Window, click on "hibernate" Tab
Uncheck "unable hibernate"
Press OK
Hope you find the above information helpful.
Please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya.
Dec 19, 2009 | HP (D7580-60003) Motherboard
My HP Pav laptop just died (shut down on me) and wont turn on
1.remove the battery and disconnect the power cord from the laptop. 2.hold down the power button for 1 minute 3.now connect it only to the power cord.keep the battery away 4. as soon as you press the power button to turn it on, keep on tapping F8 key. 5. If you see advanced option, you can choose safe mode with networking and it hit enter. 6. now remove the security like Norton or macafee and scan it with malwarebytes(www.malwarebytes.com) 7. Now, restart the computer 8. If data is not important you can restore the computer to the factory setting, but all of the data would be lost. 9.to restore the xp computer start press F10 at the startup 10. to restore the vista computer start press F11 at the startup.
Dec 08, 2009 | HP Pavilion dv9000z Notebook
I hibernated my hp laptop and it refuse to come on again
Normall hibernation can resume from a selection of key / mouse touches.
Some of the HP's resume from the power button even though it is lit.
Sep 05, 2009 | HP Pavilion dv6000z Notebook
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
Laptop Doesn't Turn On At All
To take out of hibernation,press the power button for less than 1 second.
Then go into the control panel and disable hibernation as described below.
Disable the your mouse's "ability to wake up computer" in device manager.
Use keyboard to wake up your computer.
Click Start > Control Panel > Performance and Maintenance > Power Options > Hibernate tab.
Then clear the Enable Hibernation check box.
If this doesn't resolve the issue,Please post back.
Please rate this a fixya.
May 17, 2009 | Compaq Presario M2000 Notebook
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
Hibernate mode
Press the power button it might flash
Apr 02, 2008 | HP Pavilion dv6000z Notebook
Canon Power shot sd 1000
what u have to do is when u are going to take the picture click on the little lightening bolt next to the func. set button. 2 pictures will pop up- one of a lightening bolt and another with a lightening bolt with a slash through it. hit the lightening bolt button again and it will select the slashed lightening bolt picture. this will turn flash off to turn it back on go back to the screen with the 2 bolts the same way but press the button with the flower to the right of the func. set button.
Nov 18, 2007 | Canon Cameras
Computers & Internet Logo
105 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
