Question about Intel Motherboard
SETTING UP HARD DRIVES - Intel Motherboard
    Sergeant:
  • 270 Answers
Usually, this requires a little bit more info...
On motherboards these days you have different types of connections
IDE
EIDE
SATA
SCSI.
Each has it own specifications...
Provide Operating sytem
Provide drive make and capacity
specify drive type
please tell what drive is for (replace original, or used as a backup)
Good luck
Posted on Sep 27, 2010
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
My advent 7070 does not detect 40GB sansung MP0402P hard drives
did you check for pin one on drive and on system board they must be exact red on one both places also check drive to factory defalt setting jim
Nov 16, 2010 | Samsung Spinpoint MP0402H 40 GB Hard Drive
How do set the jumpers on the HD to slave ? thanks
you can find the jumper settings printed on the top of western digital caviar hard drives
slave setting with the hard drive end jumpers facing you is 2nd from the right or 4th from the right
good luck
Aug 28, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Need to know what is jumper setting for cable select on all western digital hard drives
Welcome to Fixyah,
Jumper settings procedure will located at the front of that disc and it will show where the jumper setting was located. I suggest to you to go ahead and check it out.
Aug 11, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Jumper setting
I usually set all the drives to cable select and let the machine bios figure it out. However if you want to manually set the jumpers here is the best way I have found. This drive is an IDE drive so there needs to be two connectors on the cable for two CD/DVD drives. The drive at the end of the cable should be the Master and the inside connector should be the slave. Just a note: your machine should have two cable for IDE one is for the hard drive and the other for the CD/DVD's Most cables have two slots but it depends on your computer. On the newer machines the hard drive cable looks somewhat different than the CD/DVD cable because the hard drive cable has twice as many wires in it.
Mar 09, 2010 | Computers & Internet
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
I am trying to put western digital IDE hard disk onto dell latitude. What is the jumper setting to make it master
Here is a pdf that might help u with ur problema. Hard drives always come with a legend attached to it that says the correct pin setting to make it slave and master, should look at it first, if u dont have it look at the pdf.
http://www.wdc.com/en/library/eide/2579-001037.pdf
Nov 02, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
