Question about HP OfficeJet 7110 All-In-One Thermal Printer
Supply Expired! I have placed 2 new cartridges in the printer, however, we I close the printer door, the message to align the cartridges will show for about a second and the I get a message "Supply expired. Replace Black ink cartridge." But there is a brand new cartridge already in the printer.
  • loewencaine May 28, 2008
    it's an HP officejet 7110 all-in-one. says my cartridge access door is open and when i put in a new cartridge it says 'supply expired'.
    Genius:
  • 1,142 Answers
Reset the printer to the factory default setting that should resolve the issue, you can provide me the make and the model so i can give you the instructions how to set the printer to default factory settings.
Posted on May 23, 2008
How to install cartridges for hp deskjet 2542 printer
Barb, you need to read the owner's manual. HP's support site will allow you to download it as a pdf file, if you've misplaced it. Just insert the product model number and name and download the pdf file. Here's the hyperlink for you: http://www8.hp.com/us/en/drivers.html
Jun 16, 2015 | HP DeskJet Office Equipment & Supplies
Printer HP 1315 shows "Door Open" and does not respond to printing call
This is a more common occurrence than you might expect. The "door" referred to in the error message is actually the portion of your machine that must be lifted up in order to gain access to the ink cartridges for replacing them. You will notice that a protrusion on the lower side of the "door" surface fits into an opening in the surface below the door when the door closes, and this contacts with the door status switch to close the contacts on the switch, telling the machine that the "door" is closed. If indeed the door is fully closed, with nothing obstructing the switch from performing, then that would indicate that either the switch is defective or has come loose. After replacing cartridges, the "door" must be fully closed or you will see the error message. For troubleshooting procedures to solve this problem, go to this link: http://support.hp.com/us-en/document/c00829896
A test print page may show distorted characters at the beginning, but the characters should be shown correctly towards the end of the test page. If this is not the case then I would suspect that at least one of your cartridges is not seated properly. Open the cartridge access "door," and check the cartridge positions. When you remove and replace a cartridge, the new cartridge should be pushed back as far as it will go and then the front end of the cartridge lifted until you hear it snap into place. When seated properly, the top of the cartridge will be level.
Feb 11, 2015 | HP PSC 1315 All-In-One InkJet Printer
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Printing error message OxC18a050a unable to print
Hi
This is the error message which refers to ink system failure, printer shows this message when the ink system of the printer would not allow you to printer
Please follow the the steps given below
Make sure that the printer's power cord is connected to the walljack (Avoid if there is any surge protector or extension cord) Take out all the ink cartridges Take a clean cloth, dampen it in distilled water and with that cloth clean copper contacts of the cartridges firmly Let them dry for 2 minutes Unplug all the cables from the back of the printer while printer is turned on (After closing all the doors that are open and also keep the cartridges out) After 2 minutes, plug in the power cable Put the ink cartridges in one by one, then close all the doors again Printer would start going through some maintence and then would start aligning the ink cartridges All the best!! Regards
Oct 27, 2010 | HP Photosmart 8250 InkJet Printer
Printer will not align
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | HP PSC 750 All-In-One InkJet Printer
My printer dont want to print
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Apr 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
694 people viewed this question
Ben Johnson
