Unlock codes for philips dvdr 3510
I'm trying to find an unlock codes for philips dvdr 3510 for a dvd player put i have no luck of find one.
Can you help I would be very grateful
  • 376 Answers
Make sure no disc is loaded
Press on the RC:
0 0 8 6 0 0 0
Done!
Posted on Sep 10, 2008
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
DVDR 3300H. Machine is faulty after removal of a jammed DVD
i could not find your model as listed however, here is the Philips contact support site http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ie&userLanguage=en They have a chat facility and I'm sure you could use that to locate the service centre near you
Apr 09, 2010 | Philips Magnavox DVD/VCR Dual Player
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Apr 15, 2008 | Philips DVDR 3355 DVD Recorder
Unlock Code for Philips DVDR3575H/37
There is a YouTube video that has the secret code. WARNING: it will only work 3 times, and then the code will no longer work.
Mar 27, 2008 | Philips DVDR3575H/37
Philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Mar 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Help
Possible codes for Philips DVD Players are: 0441, 0442, 0943, 0177, 0599, 0799, 0699, 0247, 0447, 0598, 1211, 1214. More specifically, codes for Philips DVD Recorders are 0599, 0699, and 1211.
I have the Philips 3355 DVDR, and the code 0599 works on my Philips URC US2-PH5DSS.
You can visit the Philips Universal Remote Control code look-up page to find just about any manufacturer code for a Philips remote. The page is here: http://www.urc.philips.com/. I don't see your remote there, but maybe you can lookup the codes under a similar remote.
Feb 11, 2008 | Televison & Video
Code required please
hello .
try this region codes for the region codes . for philips dvdr 3380.
riz.
Feb 09, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd player
i need remote codes for philips 734 dvd player
Feb 02, 2008 | Philips DVDR 3355 DVD Recorder
Urc-4220 universal remote codes
Eaglescout, URC codes for Koss DVD Players may be 0143 or 0440.
dntom2000, without knowing the manufacturer of your combo player I can't check on your codes, but for you and anyone who needs a code, you can try using the URC lookup page at Philips.
Jan 05, 2008 | Philips DVDR 3355 DVD Recorder
Dvd player
Just google a bit like
"My brand nad type" region code unlock
You can be surprised - once it was - press 999 on remote :)
Dec 04, 2007 | Televison & Video
Televison & Video Logo
332 people viewed this question
Top Televison & Video Experts
