Question about Dell 3000cn Color Laser Printer
Dark Smear Won't Go Away
This has been a great work-horse printer, but at the moment is not much more than a 70 lb doorstop. I'd like to get this thing working again but nobody I can find locally repairs these printers. So I thought I'd try my hand at fixing it myself.
I'm getting a dark smear down the right side of every page. I've replaced the drum twice, and have replaced all toner cartridges. I've pulled out the cleaning rod and replaced the pad. I even vacuumed all the surfaces I could find to clean inside the printer and still no luck. Any idea what I can try next?
  • DrKlahn May 24, 2008
    I have a similar problem in a Laserjet 5L. Cleaned the cartridge drum and replaced the cartridge x2. The engine self-test is good even in the smearing area. I suspect damage or contamination of the transfer roller -- I'm going to open the printer and inspect it.
    Assuming the problem is the transfer roller, would someone advise me -- can it be cleaned or should it be replaced?
  • 24 Answers
It Sounds like you may have damaged, or in some way stained the Fuser Roller.
The roller is situated on the top of the unit under the smaller opening flap towards the rear. release the blue levers and examine the surface of the orange roller, chances are the roller is marked.
New Fuser units are available from a number of UK sources but are pricey at around £100 (100k copies per unit).
The other possible cause is if you are using a refilled black toner cartridge. Dell toner units don;t like being refilled more than 3-4 Times and often leave a "ghost" mark on the page. try a new dell toner in the unit and see if ithat helps.
Posted on Dec 05, 2008
What's the right weight for a heavy bag?
If you're weighing in the 140-170 lb. you should buy a punching bag weighing around 70-90 lb. if your close to 140 you should buy a 70 etc. if you a big guy weighing over 170 lb. you should get over 100 lb. bag. There is also heavy punching bags suitable for children and the weight around 25-55 lb.
Aug 07, 2012 | Boxing
Hp9300 not feeding thick paper
Based on the Media weight for a HP Deskjet 9300
The Main Tray can support up to 36 lb bond.
The Manual Tray in the Back can support up to 70 lb bond via a single sheet.
You must check the weight of the thick paper you are using to make sure your using the correct weight.
Oct 15, 2010 | HP DeskJet 9300 InkJet Printer
Timing belt markings mazda B2500 1998
Timing Belt, Sprockets & Front Cover Removal & Installation Timing belt To Remove:
  1. Disconnect the negative battery cable.
  2. Remove the exhaust side spark plugs, outer timing belt cover, and crankshaft pulley.
  3. Turn the crankshaft until the number one piston is at top dead center (TDC). CAUTION
    The camshaft belt tensioner tool (303-097) can be damaged when trying to relieve belt tension if you attempt to remove the belt without first loosening both the timing belt tensioner adjusting bolt and the spring pivot bolt.
  4. Loosen the timing belt spring pivot bolt, but do not remove it at this point in the procedure.
  5. Loosen the adjusting bolt slowly and release the spring tension.
  6. Turn the tensioner with the camshaft belt tensioner tool (303-097), against the spring pressure, clockwise to the farthest position.
  7. While holding it in this position, tighten the adjusting bolt to hold the tensioner away from the belt.
  8. Remove the timing belt.
To Install:
  1. Be certain that on piston number one, the crankshaft is at TDC with the crankshaft keyway pointing straight up and the circle on the crankshaft sprocket lined up with the notch on the engine front cover.
  2. Line up the timing marks.
  3. Install the timing belt over the crankshaft sprocket going counterclockwise over the oil pump sprocket and over the camshaft sprocket.
  4. Loosen the bolt allowing the tensioner pulley to press against the timing belt. NOTE: The timing belt tensioner should not be tightened or the belt tension will not be evenly distributed over the whole belt.
  5. Turn the crankshaft two revolutions clockwise. Next, slowly bring the crank to the number one position firing position with the keyway on the crank facing up. The dot on the crankshaft gear is lined up with the notch on the front cover.
  6. Check the timing mark alignment again. If necessary, repeat the procedure.
  7. Tighten the bolts. Torque the pivot bolt to 30-40 ft-lb (40-55 Nm). Torque the adjustment/locking bolt to 26-33 ft-lb (35-45 Nm).
  8. Install the crankshaft pulley and tighten the bolt. Torque to 93-121 ft-lb (125-165 Nm).
  9. Install the outer timing belt cover and tighten the bolt. Torque to 70-106 in-lb (8-12 Nm).
  10. Install the exhaust side spark plugs.
Sprockets To Remove:
  1. Remove the timing belt.
  2. Install the camshaft sprocket holding/removing tool (303-098) onto the sprocket.
  3. Remove the camshaft sprocket.
To Install:
  1. Place the key and camshaft sprocket on the shaft.
  2. Install the camshaft sprocket holding/removing tool (303-098) onto the camshaft sprocket and tighten the bolt. Torque to 52-70 ft-lb (70-95 Nm).
  3. Remove the tool then install the timing belt.
Outer Cover To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the negative battery cable.
  3. Remove the fan shroud.
  4. Loosen the bolts on the water pump pulley, but do not remove them at this point in the procedure.
  5. Remove the drive belt, the water pump pulley, and the fan and clutch assembly.
  6. Recover the refrigerant from the A/C system.
  7. Disconnect the A/C wiring connector.
  8. Remove the A/C compressor from the mounting bracket then remove the A/C mounting bracket with the power steering pump still attached.
  9. Remove the outer timing belt cover.
To Install:
  1. Install the outer timing belt cover. Torque to 70-106 in-lb (8-12 Nm).
  2. Install the A/C mounting bracket with the power steering pump still attached. Torque the M10 bolts and stud to 35 ft-lb (48 Nm) and torque the M8 bolt to 18 ft-lb (25 Nm).
  3. Install the A/C compressor to the mounting bracket. Torque to 16-20 ft-lb (21-28 Nm).
  4. Connect the A/C wiring connector.
  5. Refill the refrigerant into the A/C system.
  6. Install the fan and clutch assembly, the water pump pulley, and the drive belt.
  7. Tighten the bolts on the water pump pulley. Torque to 13-17 ft-lb (17-23 Nm).
  8. Install the fan shroud. Torque to 54-70 in-lb (6-8 Nm).
  9. Connect the negative battery cable.
  10. Start the engine. Check for leaks and repair as necessary.
Inner Cover To Remove:
  1. Loosen oil pump sprocket bolt.
  2. Remove timing belt, timing belt tensioner, oil pump sprocket, and crankshaft pulley.
  3. Remove inner timing belt cover.
To Install:
  1. Install inner timing belt cover.
  2. Install crankshaft pulley. Torque to 93-121 ft-lb (125-165 Nm).
  3. Install the oil pump sprocket.
  4. Install the timing belt tensioner. Torque the pivot bolt to 30-40 ft-lb (40-55 Nm). Torque the adjustment/locking bolt to 26-33 ft-lb (35-45 Nm).
  5. Install the timing belt.
  6. Tighten the oil pump sprocket bolt. Torque to 30-40 ft-lb (40-55 Nm).
  7. Torque the camshaft bolt to 52-70 ft-lb (70-95 Nm).
Jul 12, 2010 | 1998 Mazda Pickup
I need to replace the alternator on my sisters car and its not here right now and was wondering where the alternator is located so i will know if ill be able to get to it to fix it
if you have the 2.3 liter engine follow these steps...
  1. On models with anti-theft audio system , refer to Technician Safety Information .
  2. Disconnect battery ground cable.
  3. Remove lefthand charge air cooler, then righthand upper seal board, Fig. 3 .
  4. Remove condenser fan assembly.
  5. Disconnect alternator, then alternator electrical connector.
  6. Remove lefthand splash shield.
  7. Remove drive belt.
  8. Remove A/C compressor, then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  9. Remove alternator from under vehicle.
  10. Reverse procedure to install, noting the following:
    1. Torque lefthand splash shield bolts to 70 - 95 in.lb.
    2. Torque condenser fan bolts to 70 - 95 in.lb.
    3. Torque lefthand charge air cooler nuts to 12 - 16 ft.lb.
if you have the 2.5 liter engine then follow these steps....
  1. On models with anti-theft audio system , refer to Technician Safety Information for system deactivation procedure.
  2. Disconnect battery ground cable, then remove electrical harness, Fig. 4 .
  3. Disconnect terminal B wire, then alternator electrical connector.
  4. Remove righthand splash shield.
  5. Remove drive belt.
  6. Remove A/C compressor; then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  7. Remove alternator from under vehicle.
  8. Reverse procedure to install, noting the following:
    1. Torque upper alternator bolt to 12 - 16 ft.lb., then lower alternator bolt to 24 - 33 ft.lb., Fig. 4 .
    2. Torque A/C compressor bolts to 12 - 16 ft.lb.
    3. Torque righthand splash shield bolts to 70 - 95 in.lb.
Aug 04, 2009 | 1995 Mazda Millenia
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Apr 28, 2009 | HP LaserJet 2200D Printer
Paper thickness allowed
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Dec 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
All faxes sent have a dark black line going down the lenth of the
There is something on your scan glass that is blocking the light. If you open your ADF ( where you put the paper in to scan) like you are removing a jam there will be a long piece of glass. If you look at that glass there is probably dirt, ink smear, or whiteout smear on it. Clean that glass and try to copy a page. This should fix your problem.
Hope this helps.
Nov 21, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Dell 3000cn Color Laser Printer Logo
219 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
