Question about Hunter Ceiling Fan Light Switch Control
I purchased a ceiling fan with a light kit to replace one that did not have a lite kit. When I removed it, the fan had white to white, black to red, green to green, with the black wire capped off from junc box. My new fan has a Blue, Black, White and green. According to the manual, it said to connect the fan motor white to white, the fan motor black to the supply black (hot).. I connected the fan motor black to the red coming out of the box (thinking that was the same one that was connected to the old fan). Then it said to connect the blue for the light kit to the black household supply wire which I connected to the one the black that was capped in the ceiling box. The fan is too high off the ground to control with pull chain so I purchased the Hunter 27183 Ceiling Fan and Light Control which has a black, blue, red and green. In the box for the switch, the black wire was capped. One wire from the old control went to the red and the other wire went to another black from within the box but not from the ceiling. The white wire was connected to other whites so I did not touch. For the new fan I connected the black from the control (diagram says hot) to the red in the junction box, the red from the control (light), to the black in the box that was capped (comes from ceiling box) and the blue from the control the the other black in the juncture box. Greens to greens. The fan works fine but the light switch only works when the fan is run on high... on lower speeds the light goes very faint. Puzzled what to do
  • 10 more comments
  • rmoreno01 Sep 27, 2010
    Could it have been that easy ... nope. So I did as instructed. Connected the blue wire to the red and left the black capped on the ceiling fan. Now the fan only spins on the controls highest speed, no other speed is available and the bulbs only turn on the same high setting. However, the bulb does not dim as it did before.
    I left the connections in the junction box the same as before.
  • rmoreno01 Sep 28, 2010
    Yes I did replace the fan. And there are 4 wires as you describe. They do appear to come directly down to the box. In fact I could not find the breaker to turn power off when replacing the fan... well I could have tried harder. The white comes down and is tucked in the back of the box with others. Not sure if the pics helped at all.
    K np ... All green wires connect to the bare wire either in box or ceiling the blue wire is connected to a different black within the box where the old control was connected. It is not the same black coming from the ceiling.
    Thought this might be a more thorough response to the wall control question.
    Sent scan of diagram... which I found to be less than helpful..
    I am in no hurry and just want to get it right. You have been very responsive. I did not have time to implement your suggestion. Will try tonight. I can certainly understand where you are coming from. Will send you a note tonight. This is very detailed so I appreciate your time more than you know.
    OK so all wires connected and the fan speed works ok. Now the light when the dimmer is all the way down in what would be the off position glows low. The only way to turn it off entirely is to use the bottom slide switch that kills both fan and light. Kind of a master on off. But other than that does work independently. Thoughts? One more thing. The green at ceiling does not have a metal box to connect to as there is no box it is merely the conduit coming through a beam 15 ft where the sloping ceilings meet. kinda like an A. But it is connected to greens at the control switch
  • rmoreno01 Sep 29, 2010
    Nope when I said conduit I just meant the wire no metal casing so no grounding up top... could try a different one.
    Yes it clicks but light stays glowing. I can try and exchange or should I get a whole different kind.
    Ok will now have to do in the morning... Appreciate the help . Let me know when I over extend my welcome. Be good..
  • rmoreno01 Sep 30, 2010
    OK ... you nailed it was the control switch ... works like a charm. I sincerely appreciate your time, help, patience and advice. Mil Gracias.
    You guys rock. Zaraki my consultant was very thorough, clear and responsive. Great service made better by great people.
    President:
  • 834 Answers
That is kinda confusing, but it sounds like the blue wire for the light kit should also be connected together with the red supply wire for the fan motor from the ceiling wires, and not the capped black wire. That is if the two wires to the fan motor are the white and red wires from the ceiling. Normally the white wire is a neutral wire and the black is the field wire and they both are alternating current "hot" wires, and the green wires are grounded to earth ground only.
Let me know if I understood that right about the wires from the ceiling, and let me know if you require any further assistance.
See if this diagram is correct
Posted on Sep 27, 2010
  • 8 more comments
  • Zaraki Sep 28, 2010
    Did you replace the fan, and the wires from the ceiling are white and black, green, and also a separate red wire that all run together between where the fan is attached to the ceiling and the wall where the fan control switch is mounted?
    The images are very useful and thank you very much for them, and I am figuring out the wiring now and I am making you a wiring diagram, so I might have another question for you before I am done with it and and can upload it for you, and it might take a little while to finish but it should not take that long to figure it out, and also where are the green wires connected to, and where does it and the blue wire connect to in the upper image that you sent?
    Can you tell me what the directions say for the red and blue wires from the new wall mounted fan control switch and what they say they should be connected to.
    The white wire from the ceiling connected to the other white (neutral) wires in the wall switch housing is correct, the Blue wire from the control switch should be connected to the Black wire from the ceiling, and the Red wire from the control switch should be connected to the Red wire the is from the ceiling, and the Black wire from the control switch should be connected to the other black (hot) wire that comes from the wall mounting box and not from the ceiling. The green wires are also correct.
    The fan should have the Black wire from the ceiling connected to the Black wire on the fan, and the White wire from the ceiling connected to the White wire on the fan, and the Red wire from the ceiling should be connected to the Blue wire on the fan, and the green is correct.
    It would be a good idea to also confirm that those are the wires that run between the wall switch and the ceiling.
    Also, the fan control switch on the wall will now control the fan and the lighting, so be sure that the manual controls for both the fan and the lights that the chains control are set to high or maximum for the wall mounted control switch to properly control the fan speeds and lighting.
    Here is the wiring diagram that I made for you, and let me know if you require any further assistance.
    This is about as thorough as it can get, and it might not have been fast enough for you, but figuring out the wiring of an un-known home is not a very simple task, and it can take a little time to properly sort things out.
    Sorry for the type error, that should read in the top paragraph "and the Red wire from the control switch should be connected to the Red wire that is from the ceiling". The wiring diagram that I made did take a little time to make, but I assure you that it will be correct and you should not have a problem wiring in that fan and switch. The wiring diagram that you sent for that control switch was atrocious, and you would think that they would make something a little more user friendly instead of something that even a wiring technician would have trouble to figure out, and that is really one of the worst diagrams that I have ever seen, and I will also bet that they did not pay someone too much for it either.
  • Zaraki Sep 29, 2010
    That sounds like a problem with the dimmer switch side of the fan control switch, and the fan control switch might be faulty, however since there is a separate on/off switch that just might be the way that switch functions, and if the control switch is faulty or thought to be then it would be a good idea to exchange it if possible, also did the directions describe the operation of the fan control switch, and the fan motor should have the green wire grounded to the metal conduit (hopefully the conduit is metal) if there is no other metal place for a ground, and a ground clamp similar to what is used for grounding roof-top antennas should work for that.
    Also, when you slide the dimmer switch slide all the way down you should feel the slider click or lock into an off position or setting if it does have one, or does the slider for the dimmer just slide smoothly up and down all the way without clicking or locking into an off position?
    That definitely sounds like a faulty fan control switch, and I would give it a chance and exchange it first before actually condemning that fan control switch.
    I will help you to the best of my abilities to solve your problem until the problem is solved or I can no longer be of any further assistance, and I do believe that exchanging that fan control switch will solve the final problem with the dimmer part of the fan control switch.
CEILING FAN MODEL AM-1
The red wire is the hot wire for your light so connect it to the black wire on your light. The white neutral wire should connect to your other white wires on fan power wires.
Sep 02, 2012 | Hunter (25417) Ceiling Fan
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
Light does not come on in the ceiling fan
"from the ceiling fan we have black, blue, and white. On the mounting bracket is green. We installed black and blue from the fan motor to the black in the ceiling."
If your fan is working and the light isn't and they are tied to the same wire (black wire), then you might have a bad pull chain switch or bulb.
Feb 18, 2010 | Hampton Bay 56 In. Florentine IV, Brushed...
Light and fan work but does not work with wall switch
This would mean that that constant power to the fan and light is not wired through the switch right, or not wired into the switch at all. Most ceiling fans that have a light kit will have a Black, White, Green, and Red wire that comes from the ceiling and hooks into the fan and light. If it was done correctly, then the Green wire would be ground, the White is your neutral which is hooked to the other White wire, the Black wire is usually power to the light kit which will also hook to another black wire, and the Red is to the fan. Sometimes the Red and Black are reversed. If any of these wires are wired wrong, that could possibly lead to a constant power to the fan and light kit.
Feb 02, 2010 | Hunter Dryers
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Nov 15, 2008 | Hampton Bay 24750 Huntington III Ceiling...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Jun 10, 2007 | Casablanca Fan 3245T Ceiling
Dryers Logo
1,538 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
