Question about Roper RS22AQXKQ Side by Side Refrigerator
Refrigerator started smoking from the bottom vent and fire in the back bottom
  • Roper Master
  • 43,501 Answers
A capacitor blew up....take the back off you will easily see where the problem is....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 27, 2010
My lg dryer 2301 started a lint fire which set off the smoke alarm.
Your vent is clogged somewhere along the way, causing "blowback" into your dryer which builds up lint inside the cabinet and causes fires.
You need to clean out your dryer vent.
Oct 19, 2014 | Dryers
Our Kitchenaid bottom freezer refrigerator smells "smoky". Not sure what to do. Unplugged it because I'm afraid of a fire. Seems to be smoking (barely) from the back bottom panel.
Yes, unplugging your unit was a smart move. Now you need to find out if it is the fan motor or the compressor. Hopefully it is just the fan motor, that is the least exspensive and easiest to fix. If it is the compressor it may not pay you to fix it you may be better off getting a new one.
If it is the fan motor do a search for "appliance parts" input your madel number and you will get a list of parts to choose from. Check a number of different sites as the prices can vary greatly.
If you pull out your refrigerator, take off the back panel cover, you should be able to easily tell which part got over heated.
Nov 22, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
The Fridge froze all inside and the generator works constantly. The settings are set to medium. Nothing changed after turning the power off and then back on after a few seconds. I'm assuming the thermostat...
Check the vent door from the freezer to the refrigerator...when you turn the refrigerator off with the knob, does the vent door close. The bottom of your refrigerator works from the freezer blowing cold air through the vent to the bottom of the refrigerator. If it is turned all the way down, that should shut off the flow to the bottom. If any thing is broke there, it will continue to let cold air come down the vent, so check it out. The vent knob itself might not be working to turn the vent door down or off. There also, is a relay on the back of the refrigerator that controls the compressor on and off...it could be stuck in on position.
Oct 28, 2009 | LG LRTP1231W Top Freezer Refrigerator
Refrigerator Compressor smoke hot to touch
Yes this is a sign of a burn out or start relay or start capacitor defect you made the correct choice. If you need assistance let me know, Sea Breeze
Jul 02, 2009 | Refrigerators
Fire started in freezer after I washed it out.
HI, The glow was probably the defrost heater. If you didn't have any smoke or flames, you probably just happen to see the defrost heater come on. It would of been behind he rear panel down near the air vent.
I hope this helps you.
Vic
Jun 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Plastic burning smell coming from bottom front vents.
u may need to unplug it then tip it enough to see under it to see if maybe a mouse chewed on some wires and try to rewire or electic tape on some bare wires
Mar 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Smoke damage appliances in apartment fire
Just a recommendation from the ins. co. as a precaution. As long as fire did not damage them, they should be okay to use.
Feb 03, 2009 | Frigidaire PLHS269ZC Side by Side...
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Roper RS22AQXKQ Side by Side Refrigerator Logo
71 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
