Question about Toys
I have a John Deere Gator Model MP270. Where can I get a manual for this toy?
momsjustknow
  • 149 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 3 Answers
SOURCE: Gear clicking in rear
Does it go in reverse without clicking? If so then the teeth are worn over to one side. If thats it you can swap the motor and gearboxes from side to side, left to right and right to left, and get a little more time out of them. Otherwise you will need to replace the gearboxes. There are plenty of places to buy them from and they are not hard to change. No special tools. Best source of info I have found is www.modifiedpowerwheels.com They have lots of info and its all free.
Posted on Dec 18, 2008
  • 156 Answers
SOURCE: Please let me know how I can change the rear tires
My Grandkids go through these wheels every few years.
They love their Gator.
You take the center black cap off and use a socket to remove the attachment on the axle.
Here is the replacement wheels
http://www.shopjandl.com/sarp8115kny.html
They can also help you with the repair, I call them all the time..very friendly people.
hope this helps
Posted on Sep 14, 2009
Testimonial: "Thank you so much for the info. "
  • 670 Answers
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
How do i check the battery on a john deere gator model mp270 ????
check it with a multimeter and see if its showing the correct volts
Mar 03, 2012 | Toys
How do i test the battery on a john deere gator mp270
first check the charger with a multimeter and make sure that it is putting out at least 13.6 volts, then charge the batter overnight with it, then check the voltage of the battery with the multimeter and make sure that its showing at least 12 volts and write down the time and date and voltage on a piece of paper then let the battery sit for a day and check it again and see how much voltage it dropped, if it drops alot then the battery is junk and you'll need to replace it
Mar 03, 2012 | Peg Perego John Deere Gator HPX Ride on...
The gator will not go forward, but will goin reverse.
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath you can order a new one here www.powerwheelsoutlet.com
May 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
Button for "gas pedal" on gator mp270 needs to be replaced
Rob to the rescue!! lol
try this mob foe worldwide parts
">Cheers Rob yhst-49586367436770_2067_111901090
Aug 06, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
226 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
