Question about Haier hwr10xc6 Air Conditioner
Water runs down interior wall into room - Haier hwr10xc6 Air Conditioner
  • Haier Master
  • 43,501 Answers
The unit has one of two problems...
either the unit is tipped towards the inside or the holes in the back corners that drain the unit are plugged up...
heatman101
Posted on Sep 28, 2010
Bathroom leak
Most likely the problem is a leaking drain pipe in the wall, perhaps because of a failed joint. The reason it's not going down the wall to the floor of the dining room is because there is a top plate on the wall. Most likely the water is running down the bathroom wall, then out over the dining room drywall ceiling. It is finding the lowest spot in the area to accumulate and is soaking into the drywall. Since it is drain water, it is dirty and is picking up additional contaminates from the wall and causing the brown stain. It may or may not be soft, depending on how much water accumulates at one time, but it is slowly breaking down the ceiling where the stain is.
That said, are you sure it's a leak, or are you assuming that since you see the stain on the ceiling. I say this because mice, like many other rodents, usually pick one location to use as their bathroom. If you have mice in the ceiling and this is where they do their thing, you will get the same type of indication.
Nov 10, 2015 | Miscellaneous
What's the perfect combination to decor the room?
Room posters alone may not be very much entertaining as much as decorated rooms add life your overall environment. But, interior designers think that the perfect combination of an awesomely arranged interior design is to make a perfect combination of decorated rooms and posters. Visualize! How things seem to be in the presence of only a room poster. Moreover, if a room is decorated, without having a poster on its walls, it would give an incomplete look. Therefore, the best part would be to make a combination of decorated rooms and room posters. For instance, if you are having a red-colored entirely decorated room with a perfect combination of a poster on all its walls, what a beautiful look it would give to you and your guests. So, what you have to do is to go for artistic room pictures or Wall posters in order to decorate your rooms in a perfect way.
Sep 20, 2015 | Canon PosterArtist 2008
Room Tempurature on theomastat is not showing correct room tempurature
Sometimes thermostats Just go bad or are miscalibrated. Sometimes when it is on an exterior wall and it wont show the right room temp due to the wall being cold. Move to interior wall or replace.
Feb 15, 2015 | Heating & Cooling
Excess humidity in laundry room. water running down walls. why?
Check that the vent hose is hook up properly
Sep 14, 2014 | Samsung Dryers
Water leaks from the wall unit after it works on a cooling cycle for a short time. Seems there is no provision for the water to be piped away. The wall unit is situated on a dividing wall between two...
That unit was not designed to be installed on an "interior" dividing wall between two rooms. Only on an exterior wall. There in lies the problem.
Feb 03, 2011 | Heating & Cooling
There is a leak somewhere! I walked into the room while the washer and dryer were going and stepped into a little puddle of water. Upon closer inspection, I noticed water droplets on EVERYTHING in the...
to get water on the walls indicates that a hose from the taps to the back of the machine is loose or cracked allowing pressure to spray the walls
check all hoses and connections
Jun 26, 2017 | Frigidaire Affinity ATF8000FE
We built an outdoor room and the dryer vent is now "indoors".
you'll have to go to lowes or home depot and buy the rigid vent pipe not the flex type. Figure up the elbows and straight pcs. Usually vent pipe is 4,6,8 So make sure you get the correct size. Now as far as going through an existing interior since the vent pipe will be larger than the wall studs you want be able to go through the walls unless you have 6in. stud walls and the vent pipe for a dryer is usually 4in. I think. If you do have 6in interior walls you can run through them but make sure it's interior walls instead of outside wall interior walls usually dont have insulation. If you can't go through the walls your next option is simply through the each floor and out the roof or out the wall. Build a square chaise around the vent with 2x4 lumber, drywall and finish.Be careful if you go through the walls you may have to reroute wiring and water pipes.
Sep 07, 2009 | Samsung DV337 Electric Dryer
Ice build up condensation will not drain down the tube to the catch pan under the refiridgerator. As much as 3 inches of ice will build up between the veg bins, causing mold builup in fridge, Model 550...
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
Feb 17, 2009 | Sub-Zero Bottom Freezer Refrigerator
Frozen tubing in heat exchanger
The 2400ES in cold climates needs to be a twin piped unit. 3" SS venting with a combination air port made of pvc also 3 feet apart I believe on the same wall and at the same plane. Keep the cover on at all times and this will seal of the heater from the rest of the house and from freezing.
Jan 13, 2009 | Bosch AquaStar 2400ES-NG
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Haier hwr10xc6 Air Conditioner Logo
359 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
