Question about Gateway E-2000 Deluxe PC Desktop
No power i have an e 2000 i put new memory in and now i have no power the computer will not turn on. what could be wrong?
    Problem Solver:
  • 12 Answers
Take out the memory and put the original back in and see if it works then.
If not, you probably need to replace the power supply.
Posted on May 23, 2008
I have put new batteries in and a new memory card I turn on the power switch and it goes on and off straight away, what am I doing wrong,?LIz
First thought - is the memory card compatible with the camera ? Many cameras have a limit to the memory card capacity they can use.
Oct 01, 2016 | Pentax Optio I-10 12.1mp Digital Camera...
My passward wont work
hi friend
u heve to this remove your bios battery from the motherboard for the frew minites then put it back your problem will be solves
Jul 17, 2008 | Acer Aspire 3680 Laptop
My camera will not turn at all. I have brand new batteries and changed them with other new batteries (just in case). Before the camera did not turn on at all it showed on the screen "problem with...
Remove the batteries. Remove the memory card.
Install batteries only, paying close attention to inserting correctly. (Possible one was put in wrong.)
Does it start?
Yes - Power off. Insert memory card. Power on. Does it work? Memory card may be defective. Try formatting it.
If cam does not power on, return it under warrenty for replacement or refund. Or warrenty repair..
Feb 06, 2011 | Polaroid i1036 Digital Camera
I tried to change the memory card and I realized that I need another one, so, I put the older memory back, now my computer doesn't turn on, only the black screen and a beep beep :S ...what´s wrong?
Static from your body has damaged the computers components. You should have used anti-static wrist wrap. This laptop is no longer usable, buy a new one.
Jan 10, 2010 | Toshiba Satellite M45-S165 Notebook
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Hope this helps.
Oct 22, 2009 | Gateway GT5404 PC Desktop
Just added new memory and now nothing comes up when powered up I checked to make sure I had the stick in correctly, but the computer beeps when powered up, and nothing shows up on the monitor...
Try turning the computer on without the new memory stick in. If that works, it's either the new memory stick is not plugged all the way in (most probable), the new memory stick is not compatible with your computer (highly unlikely since I'm sure you checked compatibility first).
Best way to put a mem stick in is to hold it on top and push it firmly downwards until the clips that secures the mem stick click in place. :)
Oct 02, 2009 | Compaq Evo D510 PC Desktop
Memory chip now computer doesnt work
Have you tried putting the PC back to how it was before you had the problem? If you have purchased the wrong type of memory for your motherboard then this can stop your PC from booting. Check the details on the old memory to make sure they match the same as the new memory you have purchased.
If this has helped you then please rate me!
Aug 23, 2009 | E-Machines eMachines Desktop PC
I need to replace the 512 Ram Memory card with 2 new 1 gb cards
Yes that's correct simply turn off the power OFF from the computer and to make sure unplug it from the power outlet, then remove the existing 512 RAM and put the new RAM and then turn the power back ON and that's it.....
Apr 03, 2009 | Dell Dimension 2400 PC Desktop
4 beeps oi ho dc7800 PC
4 Beeps: System timer failure
Explanation: There is a problem with one or more of the timers used by the system to control functions on the motherboard.
Diagnosis: This is usually a motherboard failure.
Time for new computer.
Jan 11, 2009 | HP RT935UAABA - HP Compaq dc7800...
Memory Slot short
Probably get a techician to have a look at it. If u smelt something burn, then most likely it was due to a short circut on the motherboard in which the motherboard is faulty.
Take out the RAM and power the PC back on again. If it doesnt turn on, then the motherboard is faulty and you will need a new one.
Aug 04, 2008 | Sony VAIO Digital Studio PCV-RX680G...
Gateway E-2000 Deluxe PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
