Question about Kenmore Washing Machines
WHEN WASHING WITH COLD WATER, AFTER A WHILE THE WATER PRESSURE REALLY SLOWS DOWN. I HAVE TO TURN THE FAUCET COMPLETELY OFF, THEN BACK ON AGAIN TO GET FULL WATER PRESSURE. I USE A BOILER DRAIN TYPE FAUCET AND HAVE ALREADY REPLACED IT AND THE COLD WATER HOSE, SO THE PROBLEM MUST BE IN THE MACHINE . HOPE YOU CAN HELP ME, THANKS FOR READING ABOUT MY PROBLEM.
  • 1,531 Answers
Try and remove the water hoses and make sure there is no sediment build up in the screens to the fill valve.if things are clean then the best thing to do is replace the water valves
Posted on Sep 27, 2010
    Sergeant:
  • 270 Answers
Faucet water pressure is usually a function of the city's pressure to your house. At the time of the failure, please check other faucets, or ask a neighbor if they have the same problem.
Turning the faucet off allows the pressure to build back up, but does not fix the problem.
I have seen new construction sap water pressure as they load their water trucks often leaving whole areas without pressure.
Faucet still running
Change the O rings in the mixer.
Mar 10, 2014 | Danco Faucet Stem
The cold water tap will not completely shut off. With the handle off the cold water slows down but does not shut off. When installed I turned the valve in the direction of instructions before installing...
Not positive about the model you have, but some faucet handles can be put on when the valve is not in the correct position.
Try taking the handle back off, turn it slightly clockwise, and re-install it.
Hopefully this will do the trick.
Good Luck!
Jan 23, 2011 | Home
I have a brand new faucet not getting any water pressure? Water Pressure was fine before putting new faucet in. How do i troubleshoot this problem and get my bathroom sink running properly again?
It is very common when you first install any faucet, for the aerator on the very end of the faucet (where the water comes out into the sink) to plug up with rust or sediment. Because you had to turn off water supply, it churns up this sediment in pipes. It initially plugs up the filter/screen in aerator. Just unscrew the end & flush it out with water. Then reattach.
Jun 16, 2010 | Peerless Industries Peerless Chrome...
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
Jun 15, 2010 | Kohler K-12176-PB Fairfax Single Handle...
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Cold side of faucet, when turned on, occasionally stops flowing.
Sounds like the valve is comming apart internally. This allows the water to get into places it shouldn't and the water pressure forces the valve closed even though the handle is in the open position. Take it apart and check for loose screws and broken pieces. Lowes or Home Depot should have parts. Don't forget to shut off the valve below the faucet (if the plumber installed one) if not one will have ot shut off incomeing water supply.
Sep 02, 2009 | Price Pfister Plumbing
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
